ARIENS 48 INCH SNOW BLOWER DRIVE SHAFT GREASE FITTING
6 replies to this topic
#1 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted October 27, 2017 - 12:19 AM
Hi there in the process of repairing my 48 inch blower. I am working on the driveshaft and noticed both universal joints do not have a grease fitting. Just was wondering if any of you folks out there drilled a hole tapped and installed the fitting. it appears to be a tight fit. Finally check out the pic. I stripped the blower housing and plow blade both items ready for rust treatment mustangman
#2 KennyP ONLINE
  • 38,360 Thanks
  • 45,927 posts
Posted October 27, 2017 - 05:58 AM
Just wondering if that u-joint has holes inside for that type of modification?
#3 chieffan ONLINE
  • 10,150 Thanks
  • 6,640 posts
Posted October 27, 2017 - 07:35 AM
​I agree with Kenny.  Looks like a sealed bearing set up and if you did drill & tap a hole there is no place for the grease to go.  Only way to know is to take it apart and see if there are holes through the center of the cross.
#4 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted October 27, 2017 - 07:46 AM
There's no way the drill and tap. The cross part is a block with holes drilled into it and then pin's inserted into those holes and the caps fit onto the pins. I've tried so this is how I know.
  • KennyP, shorty and boyscout862 have said thanks
#5 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted October 28, 2017 - 08:11 AM
This is how there made.
#6 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted November 02, 2017 - 12:19 AM
Hi folks thank you everyone for all the replies concerning the u-joint issue. Now I know not to drill a hole in my u joints Thanks mustang man
#7 Scrapr65 OFFLINE
Scrapr65
  • 22 Thanks
  • 24 posts
Posted November 07, 2017 - 10:26 AM
This is called a pin and block. You can buy the pins and caps on ebay or amazon. The pins are hardened so you will need a good drill bit to drill through them.There are theads  on here to show how its done. Its the ujoint crossover threads big help for me when i was doing mine.
