Making a 316 a posi?
13 replies to this topic
#1 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 26, 2017 - 12:15 PM
Is there any way to fix the ‘one-wheelie-peely” issue on a 316?
#2 sharkman OFFLINE
sharkman
  • 358 Thanks
  • 283 posts
Posted October 26, 2017 - 02:03 PM
if it's a 316 onan (open frame)  the only way I have heard to get this is to swap in a differential from a 400 series that had the diff.lock from factory.
#3 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 26, 2017 - 02:08 PM
Ahh ok. That sounds expensive..
#4 EricFromPa ONLINE
EricFromPa
  • 3,659 Thanks
  • 3,115 posts
Posted October 26, 2017 - 04:37 PM
You won't like the posi rear experience if you use it for mowing. Making it posi traction basically doubles your turning radius depending on how long the tractor is. And when you turn the one tire will dig up your yard pretty bad especially if you have Ag tires on it.
Better off loading the tires with washer fluid or put wheel weights on it  Or both.
#5 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 26, 2017 - 04:38 PM
If it does not have the separate brake pedals you could add them and used the respective brake to stop the spinning tire and force power to the other side.
#6 chieffan OFFLINE
  • 10,164 Thanks
  • 6,642 posts
Posted October 26, 2017 - 04:46 PM
​Slow down.
#7 Littledeere OFFLINE
Littledeere
  • 1,650 Thanks
  • 1,483 posts
Posted October 26, 2017 - 06:05 PM
What Trav1s,  said is the cheapest way to make it much better
  • Dspangler said thank you
#8 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 26, 2017 - 07:03 PM
How hard is it to add the second brake system?
#9 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 26, 2017 - 09:28 PM
I assume you have an onan powered 316?
#10 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 26, 2017 - 09:34 PM
That is correct, 1987.
Edited by Dspangler, October 26, 2017 - 09:35 PM.
#11 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
That is correct. 1987
#12 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted October 26, 2017 - 10:03 PM
If the conversion of your 316 is anything like my 312, you needs parts from a  318 that can be swapped in place of the current setup.  I have not done any research into this as I have a 318 which comes with steering brakes.  My 312 is a much earlier design individual parts are different but I suspect the process is quite similar.  I'd look for an organ donor with a similar serial number to your 316 if possible and do some research on jdparts.com
Here is the pedal assembly I found in a quick eBay search
https://www.ebay.com...fkAAOSwopRYhS7c
Brake Rods
https://www.ebay.com...jsAAOxy79JSZIM~
https://www.ebay.com...W0AAMXQ9MVRicEJ
#13 Dspangler OFFLINE
Dspangler
  • 16 Thanks
  • 57 posts
Posted October 27, 2017 - 06:27 AM
Thanks!
#14 sharkman OFFLINE
sharkman
  • 358 Thanks
  • 283 posts
Posted October 27, 2017 - 07:22 AM
I did the conversion on my 316 and you need the pedals from a 318, 322, or 332.  Some welding is required.  The 316 has the same brakes as the others just a different pedal setup.
