Need Advice
wizard mtd960
17 replies to this topic
#1 MarkMasters76 OFFLINE
MarkMasters76
  • 3 Thanks
  • 4 posts
Posted October 26, 2017 - 08:22 AM
I have an opportunity to purchase an old MTD Wizard Garden Tractor with plow, and am looking for advice on whether it's a good buy. May need a starter, condenser, or points. Thank you in advance!!
I'm fairly new to the vintage tractors scene. I currently own a '75 Wheel Horse C160
  • EricFromPa, boyscout862 and KC9KAS have said thanks
#2 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted October 26, 2017 - 08:28 AM
:wave: Welcome to the forum! Nice looking tractor!
  • EricFromPa, boyscout862 and MarkMasters76 have said thanks
#3 John Arsenault ONLINE
John Arsenault
  • 2,584 Thanks
  • 1,213 posts
Posted October 26, 2017 - 08:32 AM
May want to give these guys a price if you want them to tell you if its a good buy or a goodbye.
  • boyscout862, MolonLabe and MarkMasters76 have said thanks
#4 MarkMasters76 OFFLINE
MarkMasters76
  • 3 Thanks
  • 4 posts
Posted October 26, 2017 - 08:33 AM
I think so too, but I know too little about them. Any thoughts on a fair price? It supposedly ran, but now it want start. They think maybe a starter is gone bad. Any advice?
#5 MarkMasters76 OFFLINE
MarkMasters76
  • 3 Thanks
  • 4 posts
Posted October 26, 2017 - 08:34 AM
They are asking $300
#6 KennyP ONLINE
  • 38,354 Thanks
  • 45,921 posts
Posted October 26, 2017 - 08:48 AM
Is this a vertical shaft engine? When you say 'plow', do you mean snow plow (blade on front)?
#7 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted October 26, 2017 - 09:28 AM
Horizontal Kenny, nice looking tractor, appears to be a 10hp version of the 990 and should be a excellent GT,$300 is to much in my area if it doesn't start, appears to be mid 70's
  • KennyP, boyscout862 and MarkMasters76 have said thanks
#8 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted October 26, 2017 - 09:45 AM
I'd say $200 in non-running condition.  $300 if running well.  Just my 2 cents.
  • jms180, boyscout862, Jazz and 1 other said thanks
#9 secondtry OFFLINE
secondtry
  • 1,899 Thanks
  • 1,387 posts
Posted October 26, 2017 - 10:06 AM
   If you can't start it compare it to going to the casino. If you only have to repair a wire and everything else is perfect YOU WIN. If you spend $150.00 on a starter, then hear the rod knocking YOU LOSE. Don
  • boyscout862 and MarkMasters76 have said thanks
#10 jms180 ONLINE
jms180
  • 1,516 Thanks
  • 1,567 posts
Posted October 26, 2017 - 10:53 AM
i agree with the guys you need to here it run and make your assessment on price
#11 jimmy G ONLINE
jimmy G
  • 1,197 Thanks
  • 779 posts
Posted October 26, 2017 - 11:01 AM
Tractordata says 760 68-78, found one in the threads and it is well liked lol
  • MarkMasters76 said thank you
#12 MarkMasters76 OFFLINE
MarkMasters76
  • 3 Thanks
  • 4 posts
Posted October 26, 2017 - 11:25 AM
Yes, blade on front. Has a mower deck as well, which I won't use...
Thank you all for your input!!!
#13 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted October 26, 2017 - 12:22 PM
I have the older version, the MTD 860. It has a 12hp engine and is a good tractor but I'm 6' tall and find it cramped. Mine was running and came with mower deck , snowblower, wheel weights and chains for $200 but it needed $150 of parts to repair it. Fortunately, Joes had the parts. Check it over for any diagnosible problems then decide. $200 is the most that I would consider. Do not make the mistake that I've made and fix it before buying it(loose wire). Check for the manual in our Manuals Section(3 downloads for free per day).Good Luck, Rick
Edited by boyscout862, October 26, 2017 - 02:14 PM.
  • olcowhand, jms180, MolonLabe and 1 other said thanks
#14 Jazz ONLINE
Jazz
  • 2,393 Thanks
  • 1,441 posts
Posted October 26, 2017 - 01:13 PM
The tractor looks great from here and likely well cared for...Should be able to get it for $200 since its not running.  I was at small engine shop on weekend and guy showing me a tractor that "ran 2 years ago, just needs starter"  I  was polite and said if it roars today I can squeeze 3 bills out!
#15 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,114 posts
Posted October 26, 2017 - 04:28 PM
Same exact thing as my old Wizard MTD Fourteen Hundred (960) but with a 10hp briggs instead of a 14hp briggs.  ( I should have kept it )  I paid $300 for mine with a deck and Haban blower and sleeve hitch. It ran but the deck needed some work.  By the looks of that one, she's in really good condition.  Personally I would give $300 for it but I do tend to over pay a bit for something as clean as that one is.
They are a very capable tractor. It should have the Same heavy Cast Iron Limited Slip Peerless 4 speed that JD used in the 68? 110 so it will handle plowing no problem.  My Fourteen Hundred definitely had LSD. It would spin but it had to be really really stuck in the mud. Used mine heavily for pulling large 10-14" x  20-40 foot Firewood logs down out of the woods.
Bad thing is the rear Hubs tend to break if you pull really heavy stuff. But I upgraded mine to a pair of solid hubs instead of the Split adjustable hubs.
