strange 1957 economy
4 replies to this topic
#1 cpower2004@comcast.net OFFLINE
  • 6 Thanks
  • 11 posts
Posted October 23, 2017 - 07:08 PM
The id tag says its an economy 1957. After pressure washing this is what I have learned. Rear wheel on right side has 9/16-18 lug bolts. Left side has 1/2-20. Steering colum has weld all the way around about 2" from bottom. That is only interesting because the drive shaft tube after the rear transmission has 2 weld all the way around tube 3" apart. The original paint was RED. Its on everything up to and including the bell housing. It has a 10 h/p briggs I/c engine.Flywheel was too far back and that is the reason clutch did not work.A little hone job on flywheel bore makes it easy to slide back and forth to get proper bearing to pressure plate distance. Where can I get  2 rear 24" rims and tires used cheap. I need steering wheel nut! I found shifter knobs for two dollars each. They are on the way. The engine runs great for a while then it sputters almost stops and then starts running ok again. This goes on for awhile. Took shroud off engine and found wire going to the run and stop switch broke off and laying where ever it wanted to. Still having fun!   Butch
  • Gtractor said thank you
#2 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,137 Thanks
  • 4,896 posts
Posted October 23, 2017 - 07:32 PM
JP tractor Salvage has used wheels, rims and probably tires.
#3 Bob White12 OFFLINE
Bob White12
  • 118 Thanks
  • 115 posts
Posted October 23, 2017 - 09:15 PM
Is the economy garden tractor related to the hit n miss engine? sorry I don't know much about these garden tractors.
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,012 Thanks
  • 9,644 posts
Posted October 24, 2017 - 07:07 AM
Are you using your email address for a user name? Not wise!
Edited by LilysDad, October 24, 2017 - 07:09 AM.
#5 MNGB ONLINE
MNGB
  • 1,971 Thanks
  • 1,338 posts
Posted October 24, 2017 - 07:30 AM
Hi Bob no two completely different companies, the Economy tractors were built by Engineer Products Company (EPCO) out of Waukesha, Wis, started in 1946 run with different owner last couple of yrs to 1996
Cpower the rims and center from a IH Cub will work on the rears as for the different sized bolt I'm thinking the larger one the hole got stripped and they went to the next size larger
Edited by MNGB, October 24, 2017 - 07:32 AM.
