Homemade lawn plug aerator
9 replies to this topic
#1 pryan05 OFFLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 23, 2017 - 05:40 PM
I built a plug aerator to be mounted on the three point hitches of my tractors.  I used 5/8" stainless hydraulic tubing for the tines. I cut a slot in them and opened them up with a tapered punch.  A patio stone cut in two for weight/  It works ok.. it doesn't push the plugs right thru most of the time.  It needs a bit of tweeking.  Basically another excuse to use my tractors!
Edited by pryan05, October 24, 2017 - 03:51 PM.
  • Gtractor, Alc, hamman and 8 others have said thanks
#2 pryan05 OFFLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 23, 2017 - 05:42 PM
#3 KennyP ONLINE
  • 38,376 Thanks
  • 45,931 posts
Posted October 23, 2017 - 05:43 PM
Cool implement!
  • boyscout862 and pryan05 have said thanks
#4 propane1 ONLINE
propane1
  • 8,723 Thanks
  • 4,130 posts
Posted October 23, 2017 - 08:22 PM
That’s neat. Nice lookin tractor.
Noel
  • pryan05 said thank you
#5 chieffan ONLINE
  • 10,158 Thanks
  • 6,642 posts
Posted October 24, 2017 - 08:27 AM
​The plugs will push through if the plug is a bit smaller or the same size as the tube.  Where you flared the end makes the plug larger.  Like the punch type leather punches, sharpened on the outside.  Neat looking set up just the same.
Edited by chieffan, October 24, 2017 - 09:33 AM.
#6 Jazz ONLINE
Jazz
  • 2,393 Thanks
  • 1,441 posts
Posted October 24, 2017 - 02:16 PM
I built a plug aerator to be mounted on the three point hitches of my tractors.  I used 5/8" stainless hydraulic tubing for the tines. I cut a slut in them and opened them up with a tapered punch.  A patio stone cut in two for weight/  It works ok.. it doesn't push the plugs right thru most of the time.  It needs a bit of tweeking.  Basically another excuse to use my tractors!
Very slick and no doubt a some premium time  to manufacture although I believe you cut a slot, not "cut a slut"...Spell check won't pick that up:)
  • KennyP and pryan05 have said thanks
#7 shorty ONLINE
shorty
  • 5,482 Thanks
  • 5,262 posts
Posted October 25, 2017 - 04:27 AM
But my personalized spell check saw it and read slot. I had to go back and see what I missed.
  • pryan05 and Bob E have said thanks
#8 Bob E OFFLINE
Bob E
  • 126 Thanks
  • 101 posts
Posted October 25, 2017 - 07:22 AM
Cool.
I've thought about making one of those, but I've been holding out for a good deal on a used one.
There might be an idea or to in these.
#9 pryan05 OFFLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 25, 2017 - 05:48 PM
That what I was thinking to do with the tines.  Thank you.  I been looking for a used tow behind for a while.  Definitively the way to go to save a ton of time.
Cool.
  • Bob E said thank you
#10 pryan05 OFFLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 25, 2017 - 05:49 PM
i fixed it :)
  • KennyP and shorty have said thanks
