New Carb?
4 replies to this topic
#1 jnmaietta OFFLINE
jnmaietta
  • 1 Thanks
  • 2 posts
Posted October 21, 2017 - 10:48 PM
I just bought a Bolens qt 16 with a loader. I am in Maine btw. It is a 2425A.
It only runs of I choke it all the way but it coughs and stutters and dies eventually.
Thinking I might just buy a new carb for it. It is the original I believe. Maybe cheaper to just buy a new Briggs carb?
Thank you!
  • Xrperry said thank you
#2 EricFromPa ONLINE
EricFromPa
  • 3,313 Thanks
  • 2,967 posts
Posted October 21, 2017 - 11:55 PM
QT16 should have a 16hp Onan BF MS.  Please post a Picture of the engine.
New carbs for an Onan are EXPENCIVE if you can find them. $600+ from SearsPartsDirect   https://www.searspar...&brandName=ONAN
Sounds like your fuel pump needs rebuilt. The old Briggs opposed twins act the same when the fuel pump Diaphragm gets hard. The rubber parts in the fuel pumps either get rock hard or fall apart.
This carb kit has the fuel pump rebuild kit with it. Pretty good deal @ $70. SearsPartsDirect list price is $130 + shipping for the same kit.
https://www.ebay.com...J4AAOSw5VFWHvkI
#3 chieffan ONLINE
  • 8,992 Thanks
  • 6,161 posts
Posted October 22, 2017 - 07:22 AM
​My Onan had the same problem when I got it.  Cleaned the carb and put an after market electric fuel pump on it for about $10.  Put a fuel shut off valve right at the carb.  Problem solved.
#4 KC9KAS ONLINE
KC9KAS
  • 5,240 Thanks
  • 4,622 posts
Posted October 22, 2017 - 09:50 AM
I just notice a problem with my Wheel Horse 312 H having to run with the choke pulled out.
The choke conduit slipped in the clamp and the choke handle/cable had to be pulled out about 1/2" for the choke to actually be opened!
Adjusted the cable and all is well!
  • EricFromPa said thank you
#5 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,841 Thanks
  • 2,052 posts
Posted November 01, 2017 - 07:48 AM
Sorry,just saw this post,I don't have anything right now,Thanks for asking,Rick
