Milwaukee portable band-saw stand
5 replies to this topic
#1 pryan05 OFFLINE
pryan05
    LGT
  • 688 Thanks
  • 376 posts
Posted October 20, 2017 - 03:18 PM
I have a corded Milwaukee Band-saw that I thought would be more useful if it were setup up in a stand so it can be used as a vertical band-saw.  So as most do I did an internet search and found a good build on You Tube.  It's called the quikee 3, the reason I chose this stand is the fact that it can be removed from the stand very quickly to be use as a regular band saw.  Super happy with the stand and the band saw has now become one of my favorite tools.
The first thing to build it the spacer under the handle to that the band saw can be secured to the stand by simply threading a screw into it.  I used three pieces of 3/8" flat bar, staggered them to fit in the notches of the band-saw and tacked them together.  Then drilled and taped for 5/16" and place a hole thru the top so a longer handle bolt can be put threw it.
the base is simply a flat piece of steel with 1/2" key stock welded were the bottom of the handle sits.
Than made an adjustable table with on pipe that fits into another.
There is also a dowel to hole the trigger down that jut wedges in the handle.  A switch box is to be built.20171018_182300.jpg
If you have one of these band-saws this stand is worth building to get yourself a nice little vertical band-saw.
Sorry about the pictures?
  • jhn9840, Gtractor, KennyP and 7 others have said thanks
#2 jms180 OFFLINE
jms180
  • 1,790 Thanks
  • 1,696 posts
Posted October 20, 2017 - 06:49 PM
very nice i like it nice work also
  • pryan05 said thank you
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,450 Thanks
  • 10,178 posts
Posted October 20, 2017 - 07:21 PM
That would be handy, nice work.
#4 TomLGT195 OFFLINE
TomLGT195
  • 4,096 Thanks
  • 2,926 posts
Posted October 21, 2017 - 05:52 AM
A couple pics without the saw in it would be nice to see. please.
#5 pryan05 OFFLINE
pryan05
    LGT
  • 688 Thanks
  • 376 posts
Posted October 22, 2017 - 08:50 AM
  • TomLGT195 said thank you
#6 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 27, 2017 - 09:09 AM
Great Project !!
