got my plow on my 953!
7 replies to this topic
#1 TravelinJavelin OFFLINE
TravelinJavelin
  • 127 Thanks
  • 221 posts
Posted October 19, 2017 - 01:59 PM
after looking all summer for one i was loosing hope unless i wanted travel over 200 miles for one but i found a deal 30 miles from home trying to just buy the plow itself ....wasn't happining i told him what i had to spend got for half  the price so i did the deal came with 36" rear mowing deck too then he had to get the plow from behind the shed and was lugging out a true A frame plow which was exactly what i needed and only thing didn't get was the angle rod so looked around on ebay found a couple and saw $60.00.. wasn't happining so i called my local steel shop up the road had one made for $21.00....that was more like it i thought....anyways here it is see what you think?
  • KennyP, CRFarnsworth, boyscout862 and 6 others have said thanks
#2 glgrumpy OFFLINE
  • 8,621 Thanks
  • 7,926 posts
Posted October 19, 2017 - 02:33 PM
Looks fine, Horse plows are one of easiest to use and mount I've ever had. Tractors always pushed good too, even at times w/out chains. Those big wheels may not need much to be able to push. Chains be good idea tho, might have to get truck chains with the big tires.
  • boyscout862, Leonard VanCamp and TravelinJavelin have said thanks
#3 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted October 19, 2017 - 03:45 PM
Nice snow mover there. Those 15" tires work so much better than the 12" tires. Very solid machines they were.
  • boyscout862 and TravelinJavelin have said thanks
#4 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted October 19, 2017 - 06:08 PM
I have "built" a couple of angling rods as well as the left/right/center lever. Fairly easy if you know what length is needed.
#5 Leonard VanCamp OFFLINE
Leonard VanCamp
  • 517 Thanks
  • 394 posts
Posted October 19, 2017 - 10:24 PM
My uncle has a GT14 and that thing pushes like a small dozer. While I'm a JD fan, I must say that old girl is one of the stoutest built GT's I've seen.
  • TravelinJavelin said thank you
#6 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,693 posts
Posted October 20, 2017 - 04:00 AM
I have used my WH GT-14 for snow plowing for several years. It is a beast! The only problem I have had is the plow frame hits the steering components making it difficult to turn with the plow up.
#7 TravelinJavelin OFFLINE
TravelinJavelin
  • 127 Thanks
  • 221 posts
Posted October 21, 2017 - 01:31 PM
yeah i got lucky there i measured 32" and added a inch to the bend work and couldn't of done it better and drilled some holes on my press and drilled out some washers too and came together awesome!
#8 TravelinJavelin OFFLINE
TravelinJavelin
  • 127 Thanks
  • 221 posts
Posted October 21, 2017 - 01:41 PM
well i 've tried my plow in dirt already and dam happy is all i can say love that hydro lift and she will push!!! been playing grader man with it on my property line and main road and its awesome ....i put it in first gear run above idle and the old kohler chugs away now the next thing i've got to do left is new oil pan gasket and tranny gasket with a seal on the pulley side and will be race ready then back to my snowblower attachment project
