Offer suggestions
63 replies to this topic
#46 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,272 Thanks
  • 5,567 posts
Posted July 01, 2011 - 01:20 PM
Looks like you got yourself a lot of stuff there and some good stuff too. That 2cyl. engine is going to be a challenge to install, different RPMs and no governor on it.
Be nice to get that hyd. lift working on a good tractor. Did you see the belt on the deck, somebody's got it on wrong.
#47 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 02:13 PM
:D
MESS???
Beauty is in the eye of the beholder.
Man .... you need to take a little drive and stop here ..... everything is beautiful !!!! (don't forget to bring $$$):D
#48 olcowhand ONLINE
  • 41,191 Thanks
  • 31,428 posts
Posted July 01, 2011 - 02:17 PM
Put that deck belt on right Alan & maybe things won't look so messy! LOL Just noticed the belt is routed wrong on the center blade pulley.
#49 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 02:22 PM
Alan .... here is a beauty .... on ebay over in Canton Ohio ....WOW
#50 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 03:33 PM
Thats the same pump/reservoir used in early Cubs and Deere ...
http://gardentractor...0051-large-jpg/
#51 IamSherwood OFFLINE
  • 8,391 Thanks
Posted July 01, 2011 - 06:43 PM
Really? You sure about that.
I have no idea, but that would sure make for easier hunting.
#52 IamSherwood OFFLINE
  • 8,391 Thanks
Posted July 01, 2011 - 06:55 PM
Hey Alan, that "Power Lift" Decal/plate looks kinda crudy. If you don't want it, don't throw it out. PM me.
#53 IHCubGuy ONLINE
IHCubGuy
  • 1,523 Thanks
  • 1,598 posts
Posted July 01, 2011 - 07:56 PM
It looks similar as far as the tank is concerned. Cubs had the valve and everyting built right into it. I cant tell if this does from the pic.
#54 MH81 OFFLINE
Posted July 01, 2011 - 07:58 PM
I won't be up there for a few days, will try to get better pics.
#55 HowardsMF155 ONLINE
  • 2,861 Thanks
  • 2,987 posts
Posted July 01, 2011 - 08:10 PM
So I was just looking at this thread and was wondering: Has anyone tried using a power steering pump? Seems like there would be thousands in the local junkyards.
Howard
#56 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 08:16 PM
Howard
My Dad has a homemade tractor with a plastic power steering pump..... works fine
#57 IHCubGuy ONLINE
IHCubGuy
  • 1,523 Thanks
  • 1,598 posts
Posted July 01, 2011 - 08:18 PM
Howard
I've seen it done before. I have a hydraulic pump off an old Case combine we used to have at the farm I saved for such a project. Haven't gotten around to the project yet but if I ever do the pump even has a diverter built in to split for hydraulic power and power steering off the same pump. Only problem is its way bigger than I'd ever need at 15GPM.
#58 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 08:42 PM
Could this be what Alan is up to? A rig like this with mower deck and hydraulic lever would be a real head turner:D
Posted Image Posted Image
#59 FirefyterEmt OFFLINE
FirefyterEmt
  • 451 Thanks
  • 855 posts
Posted July 01, 2011 - 09:16 PM
Hmmm... you know, dual hydro rear ends hooked up to both run. Then custom build the two seat pans so that the fenders meet in that center and flow seamless. Then build a lid that covers both seat pans and hinges up at the front like stock. Combine that with a tiny wood stake body sides, and load that back end with WEIGHT. I bet it would plow like a bat out of H...! Bwahaahhaaa
#60 MF14 plowday special OFFLINE
  • 34 Thanks
  • 255 posts
Posted July 01, 2011 - 09:22 PM
That rig is on Craigslist Zanesville Ohio.... price is $500..... tag axle is belt driven.
Ya that hirth will smoke those tires for sure ... I am curious to know the cc's
