Eaton 11 control shaft seal
5 replies to this topic
#1 pryan05 ONLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 18, 2017 - 07:00 PM
Anyone ever change the seal for the directional control shaft?  Mine is leaking and just wondering if it can be done while still in the tractor?
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,009 Thanks
  • 4,416 posts
Posted October 18, 2017 - 07:53 PM
I did one, but off the tractor. Should be easy enough on, Obtain the proper seal, remove linkage and drain oil, pry old seal off with a small screwdriver. Change fluid and filter.
  • KennyP, TomLGT195 and pryan05 have said thanks
#3 KennyP ONLINE
  • 38,474 Thanks
  • 45,969 posts
Posted October 19, 2017 - 05:52 AM
If you don't mind laying under there to pry it out, looks simple to do.
  • pryan05 said thank you
#4 pryan05 ONLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 19, 2017 - 06:07 PM
Good stuff, I get that done and post the replacement seal number.
#5 pryan05 ONLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted October 23, 2017 - 05:25 PM
So I got the seal changed here are the things that I found that should be shared.
  - The shaft for the control lever is tapered and required lots of force to remove it.  I ended up dimpling the end of the control shaft with the drill and using a two jaw puller.
  - To use a puller on the shaft, both hydraulic lines must be removed to have room for the puller.
Here is the seal number
#6 KennyP ONLINE
  • 38,474 Thanks
  • 45,969 posts
Posted October 23, 2017 - 05:26 PM
Glad you got it changed out!
