John Deere 18 trim mower
39 replies to this topic
#31 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted October 29, 2017 - 07:34 AM
Maybe some linkage is out of place?
  • Trav1s said thank you
#32 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted October 30, 2017 - 09:30 AM
Great question.  I will check out the pics when I removed air cleaner and see what I can find.
Edited by Trav1s, October 30, 2017 - 09:33 AM.
#33 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted October 31, 2017 - 01:22 PM
Messed with the carb setting and now it runs properly at WOT but the throttle control will not impact engine RPM.  Hope to get to the service manual later today.
#34 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted November 04, 2017 - 03:30 PM
Grabbed the manual and made some adjustments to the linkage and the carb including increasing the low-speed idle.  Now it runs like a top and the throttle varies the engine RPM.  Also sharpened the blade while I had it in the garage.  Put the mower in the shed where it will likely sit til spring.
  • Bolens 1000 said thank you
#35 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted November 05, 2017 - 10:23 PM
Ready for winter
#36 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted November 06, 2017 - 04:37 PM
Ok... I grabbed it off of the storage shelf, filled the tank, and used it to cut the entire lawn.  I am impressed with it - light and easy to push and did a great job with the remaining leaves in the yard.  It's a keeper!
#37 dodge trucker ONLINE
dodge trucker
  • 2,455 Thanks
  • 3,135 posts
Posted November 06, 2017 - 06:12 PM
my most recent JD walk behind looks like the one on the bottom of your shelf unit.....
  • CraftsmanGT said thank you
#38 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted November 06, 2017 - 09:33 PM
Got the same one on the bottom, too.
#39 Trav1s ONLINE
Trav1s
  • 3,314 Thanks
  • 4,368 posts
Posted November 06, 2017 - 10:22 PM
That's a 21SP of the same vintage with a 4 HP Briggs if I recall correctly.  Need to get the push handle fixed before it goes back to work.
  • Bolens 1000 and CraftsmanGT have said thanks
#40 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted November 07, 2017 - 01:45 AM
Mines the non self propelled and a bit newer (1982) but same thing otherwise.
  • Bolens 1000 and Trav1s have said thanks
