John Deere 18 trim mower
39 replies to this topic
#1 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 16, 2017 - 09:22 PM
So this showed up on CL in Iowa city about two weeks ago. I watched the price drop and called on it after a hospital visit. Turns out the guy was selling it for his father in law who worked for Deere. It has been sitting on a shelf in the garage and needed a new home. He was happy it was going to someone who would appreciate it. Really nice original condition and the chute is still on it! I checked it when I got it home and there is no spark.
  • Bolens 1000, olcowhand, KennyP and 3 others have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 16, 2017 - 09:25 PM
More pics
  • Alc, KennyP, CRFarnsworth and 2 others have said thanks
#3 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 16, 2017 - 09:27 PM
The air cleaner foam is powder
  • KennyP and jd.rasentrac have said thanks
#4 EricFromPa OFFLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted October 17, 2017 - 03:51 AM
wow that wasn't used much at all. You never see the stamp on the inside of the air cleaner. I like the little striper roller. Nice little mower.
#5 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted October 17, 2017 - 05:57 AM
Nice looking mower. Pull the flywheel tin and clean the rust off the flywheel and mag and I bet it will fire.
  • Trav1s said thank you
#6 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 17, 2017 - 06:27 AM
I will try that on Friday when I have time to play.
#7 dodge trucker ONLINE
dodge trucker
  • 2,429 Thanks
  • 3,121 posts
Posted October 17, 2017 - 08:03 AM
If you're gonna pull the flywheel might as well throw a set of points and condenser in there. On the Deere that I just got they were burnt up bad.
On the subject of cleaning the flywheel where the magnets are I have been told years ago by some old timers that doing so was a waste of time...I say "sometimes".
On another note your mower is a twin to one that I pulled from the curb and revived back in the 80s and then wore out for real, before I parted ways with it. It certainly wasn't wore out when I got it, it just needed some maintenance. As I remember I windowed the block on it several years later.
Edited by dodge trucker, October 17, 2017 - 08:05 AM.
#8 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 17, 2017 - 09:41 AM
I have another one of these that I wanted to restore but the deck is not near as nice and has some additional holes drilled on the chute area.
#9 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 17, 2017 - 10:01 AM
I was going to do the points and condenser since there is no spark.  Also going to do a plug and rebuild the carb while I am at it.  Still not the most comfortable with these Briggs carbs...
Edited by Trav1s, October 17, 2017 - 03:26 PM.
#10 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted October 17, 2017 - 01:48 PM
Just: I like it!
#11 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 17, 2017 - 02:58 PM
Here are a few more pics and from what I can tell it is a standard model 18
Model - M18RD
Serial - 32966
Briggs engine model - 92508
#12 EricFromPa OFFLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted October 17, 2017 - 04:07 PM
Might just need the points cleaned. But I'm betting it will need the carb rebuilt. Those old Automatic Choke carbs do not run if the diaphragm is hard and I can bet it will be rock hard. 90% of the time they rip if you try to take the carb off of the tank anyway.
Any more pics of the roller? Does it have bearings in it?
Carb kit # is Briggs & Stratton 494622 or Stens 520-545 or OREGON 49-137
Cheap on Fleabay
https://www.ebay.com...494622&_sacat=0
#13 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 17, 2017 - 09:22 PM
Manual says 5th digit in the model number is production year so is it fair to say D = 4 making it a 1974 model year?
There's not stripe roller on it - that is a piece of angle metal that braces the hand push bar.
#14 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 18, 2017 - 08:39 AM
Just sent a list of items to Bolens 1000 for Briggs parts "fix"
  • Bolens 1000 and Canawler have said thanks
#15 Trav1s ONLINE
Trav1s
  • 3,305 Thanks
  • 4,359 posts
Posted October 19, 2017 - 03:50 PM
Goodies ordered and fun will continue next week.
