Electric PTO
5 replies to this topic
#1 jeffsang OFFLINE
jeffsang
  • 9 Thanks
  • 10 posts
Posted October 13, 2017 - 08:46 PM
Hello
Im attempting to remove the electric PTO from the engine shaft.  I removed the large center bolt, the outer cover has some sort of tamper proof screws, will get them off tomorrow.  Does it slide off or does it need pulled with a puller?  Thanksfor any advice.
Jeff
#2 jeffsang OFFLINE
jeffsang
  • 9 Thanks
  • 10 posts
Posted October 13, 2017 - 08:47 PM
This is on a Jacobsen 1450.
#3 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted October 13, 2017 - 09:19 PM
Different machines, Different removal methods. A model type and number is usually needed to answer a question like this.
#4 poncho62 OFFLINE
poncho62
  • 2,123 Thanks
  • 1,790 posts
Posted October 14, 2017 - 05:52 AM
<Mine have just slid off by removing that center bolt and the ones that bolt the plate to the front of the block.
ford-lgt-125-lgt-145-lgt-165-tractor-ele
Edited by poncho62, October 14, 2017 - 05:56 AM.
#5 MM MARK OFFLINE
MM MARK
  • 82 Thanks
  • 38 posts
Posted October 14, 2017 - 08:09 AM
If this is a Chief 1450 when you take the bolt out of the crankshaft if it does not slide off screw a 1"-8 bolt in threads inside clutch bore this will push off of the crankshaft.
#6 jeffsang OFFLINE
jeffsang
  • 9 Thanks
  • 10 posts
Posted October 14, 2017 - 08:22 PM
Thanks, it finally just pulled off.  I do have the large inside threads, screwing a bolt in was my next move.
