Pit Cart Project Started
95 replies to this topic
#16 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 18, 2017 - 03:26 PM
Todays progress picture gives a idea how the whole project might look when finished. I built several brackets today to hang sanders, nibblers and air drills on the rear . Also finished some upside down welding and attached the tool box and middle welder secure. I am already getting use out of the 12 outlets. I will design the front to carry a few more tools also . With the little wider placement of the rear tires that should make it more stable and not top heavy.
  • CRFarnsworth said thank you
#17 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 19, 2017 - 04:34 PM
Front axle parts cut out and welded together today . Also got the front pivot pin and faceplate welded on. Last I got the pivot tube cut and the matching faceplate for it welded in place. Next I will extend the front cart frame and attach the pivot tube to the frame with plenty of frame braces. This was a easy and inexpensive design for the steering considering the duel wheel setup. Otherwise I would have built a traditional  axle with spindles and tie rods.
#18 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 21, 2017 - 02:31 PM
Next progress picture , today I cut out the parts for the front steering support , slowly making progress
  • CRFarnsworth and Jazz have said thanks
#19 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 22, 2017 - 01:13 PM
Progress today I cut out the parts for the T-handle and hinge brackets. I also got them all welded together.
#20 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 24, 2017 - 03:58 PM
Welding Cart Progress- Today I got the front fenders attached , the front frame extension finished and some new front shelves . Then I got some red paint on the new metal. Next I will work on the back side. Very happy how the T-handle steers very easy. Once I get the pivot pin and face plates greased it will be perfect.
  • CRFarnsworth and tiretrx have said thanks
#21 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 27, 2017 - 09:05 AM
Portable Workbench Progress - I got the rear of the cart looking good and all the cords and cables organized . No more tangled mess . Now I will move to the top of the table and build a couple stands for a retractable worklight, a retractable multiple electric cord and a retractable air hose. Also a stand for a radio.
  • jhn9840 and tiretrx have said thanks
#22 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 27, 2017 - 06:09 PM
Here are the last four additions to the moving welding cart. I built the supports and shelves for them this afternoon and got them painted. Tomorrow I should have the cart done.
  • jhn9840, gopher, CRFarnsworth and 1 other said thanks
#23 Jazz OFFLINE
Jazz
  • 2,677 Thanks
  • 1,549 posts
Posted October 27, 2017 - 09:59 PM
My neighbour called my welding cart the War Machine but yours is much more substantial.  Great work!
#24 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 28, 2017 - 05:35 PM
Thanks , Portable workbench, rolling welding table or pit cart, I guess its a little of all of them combined. I got it pretty much done today . A week ago I loaded it up with a variety of my most used tools and I been working off this cart 95% ever since. I have 13 tool boxes and this is awesome . I love it. I pulled it outside today through the front garage and it pulls a little harder than I thought , ha,ha. But it does roll very smooth and turns great. I will post a video of me pulling it out of the workshop.
  • Allis Chalmers Tractors said thank you
#25 jhn9840 ONLINE
jhn9840
  • 468 Thanks
  • 401 posts
Posted October 28, 2017 - 07:03 PM
Very nice. Look forward to seeing the video.
jhn9840
John
#26 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted October 29, 2017 - 08:40 AM
Thanks, The video is now on You-Tube, video number 215. Not sure how to attach it here?? But if you click on the link below it takes you there.
Edited by Don Campbell, October 29, 2017 - 08:41 AM.
  • jhn9840 said thank you
#27 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 29, 2017 - 09:19 AM
  • jhn9840, MFDAC, Sawdust and 2 others have said thanks
#28 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted November 09, 2017 - 07:17 PM
I have 13 cheap tool boxes, the last several days I have been taking them apart cleaning everything , adjusting the slide brackets and adding lube. It is helping make the drawers slide much better. Today I moved 4 top chests under 3 workbenches. Tomorrow going to move a bottom chest under another bench. Trying to get more organized. Then next week I want to stretch another metal table and insert two bottom chests together and add bigger tires . I have many smaller tires and without a drill press, a vise , welders , etc. the smaller tires will work perfect. It will have a pull T- handle handle too but just have drawers for tools. I love how the first one can be moved around so easy I just got to make another simpler version. I will share my progress next week.
#29 Don Campbell OFFLINE
Don Campbell
  • 1,581 Thanks
  • 1,188 posts
Posted November 10, 2017 - 06:05 PM
Todays project I used the plasma cutter to cut out the old drawers in this workbench so I could insert these two lower toolboxes. This will be much handier to have all these extra drawers at the main workbench. I also cleaned and lubed another tool chest today. The second photo you can see one of my mini workbenches made from a cheap box with a short piece of countertop . It is very handy and moves very easy. Also the second photo shows two of the lower boxes I will merge into one rolling toolbox starting next week. This will give me more floor space and make the other empty metal table much more practical.
#30 lrhredjb ONLINE
lrhredjb
  • 879 Thanks
  • 658 posts
Posted November 10, 2017 - 07:38 PM
Looks good! BTW did you get a killer deal on some red paint?
  • Sawdust said thank you
