Fixing up the Ford Model A Doodlebug
136 replies to this topic
#106 tiretrx OFFLINE
tiretrx
  • 2,256 Thanks
  • 1,222 posts
Posted November 17, 2017 - 08:45 AM
Speaking of the Loboy; maybe this will give you the itch.
That's a hoot, Rich. Is that two auto fenders joined, and one headlight? Like a tractor Minion!
The Loboy is right next to the Doodlebug in the shop. It not liking me right now.
  • KennyP, MFDAC, LilysDad and 1 other said thanks
#107 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,288 Thanks
  • 9,776 posts
Posted November 17, 2017 - 01:22 PM
The description with the photo said it was made with a '51 Gravely and Studebaker fenders.
  • Alc, MFDAC and tiretrx have said thanks
#108 tiretrx OFFLINE
tiretrx
  • 2,256 Thanks
  • 1,222 posts
Posted December 05, 2017 - 03:50 PM
Been waiting on a part to come in, but in the mean time I changed some gaskets and fluids. The part was another Model AA u-joint. These things are rarer than hen's teeth I've come to find out. Model A u-joint? No problem. AA's......good luck. Fortunately, because I'm stubborn, and got lucky, I tracked one down on the Ford Barn forum. Not only was it in great shape, but it was very reasonable(35 skins). My thanks to Roger on the West Coast!
Now, I have two. Now, I can make a proper driveshaft(I hope) using authentic period Ford AA parts. Thing is......I don't have a drive shaft. Checked into 1-1/4" ten splines. They go for money, and they're from a country I'm not high on getting my stuff from. So, after some noodling, to the vertical mill I went. The normal process, as I understand it, is to use a round milling cutter with the proper profile in a horizontal mill running axially down the shaft, index the shaft, repeat. I don't have that setup. Time to improvise.
First we turned a couple blank ends on a lathe.
That was chucked in a 4th axis in a vertical mill. Using a 7/32" end mill, I made 10 blind end slots 36 degrees apart. At the blind end, I ramped out the end mill for a smoother transition. It somewhat replicates what the radius of a round milling cutter would produce.
If you look close at this picture, you can see that this process creates a "bow tie" shape to the splines.
To make the splines square I took an 1/8" end mill, and after an initial index of 18 degrees, I milled each side of the 10 splines. They being indexed at 36 degrees. Part came out to size and slid right in the u-joint on the first try. Step one, done.
  • Alc, jdcrawler, KennyP and 11 others have said thanks
#109 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted December 05, 2017 - 04:05 PM
That is an excellent job of index milling.
I really like this idea and think that it will make a much better looking drive shaft then the flex tube.
Edited by jdcrawler, December 05, 2017 - 04:21 PM.
  • KennyP, tiretrx, WNYTractorTinkerer and 1 other said thanks
#110 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 05, 2017 - 05:08 PM
Glad you have the machining experience to tackle this! Looks great!
  • tiretrx and Austen have said thanks
#111 Cvans OFFLINE
  • 6,640 Thanks
  • 6,126 posts
Posted December 05, 2017 - 06:53 PM
Nice to see your back to making progress. Kind of been missing your posts.
  • KennyP and tiretrx have said thanks
#112 SimplyRad OFFLINE
SimplyRad
  • 1,095 Thanks
  • 837 posts
Posted December 06, 2017 - 08:02 AM
Making a gear or spline shaft is an interesting process. The factory where I worked as a maintenance machinist had a few gear cutters and an indexing machine. How did you index without one?
  • tiretrx said thank you
#113 tiretrx OFFLINE
tiretrx
  • 2,256 Thanks
  • 1,222 posts
Posted December 06, 2017 - 09:31 AM
Thanks a lot, Ray. Once I got through the "hope" of the flex working out, I realized it was time to pony up and try and do it proper. Just another reason my projects go on so long, I guess.
Thanks Kenny, much appreciated.
Thanks Chris, it's good to have the part in hand, so we can get busy again.
The chuck in the mill is a 4th axis. Basically, I program it's positions using an A readout. I do have a Bison conventional indexing chuck for the Bridgeports, but it's pretty tired, and I didn't have the right milling cutter.
  • jdcrawler, KennyP, Cvans and 2 others have said thanks
#114 tiretrx OFFLINE
tiretrx
  • 2,256 Thanks
  • 1,222 posts
Posted December 08, 2017 - 03:56 PM
Worked on the driveshaft today. First parted the splined ends off, then turned a plug on the end. These will get welded onto the ends of the 6" long piece of pipe.
  • KennyP, Cvans, MFDAC and 3 others have said thanks
#115 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 08, 2017 - 04:01 PM
Nice work! Know who to go to if I need something like this! LOL
  • Cvans, tiretrx and Mark 149 J. have said thanks
#116 MFDAC ONLINE
MFDAC
  • 3,214 Thanks
  • 1,586 posts
Posted December 08, 2017 - 09:19 PM
Great work Ellis, keep the updates coming!
DAC
  • Cvans and tiretrx have said thanks
#117 SimplyRad OFFLINE
SimplyRad
  • 1,095 Thanks
  • 837 posts
Posted December 09, 2017 - 09:36 AM
That is some good work.
#118 CRFarnsworth ONLINE
CRFarnsworth
  • 4,664 Thanks
  • 2,140 posts
Posted December 09, 2017 - 10:50 AM
When you weld them will you need to index them to align the splines or will it matter?
The voice in my head tells me the yokes will need to be aligned to each other.    Rick
Edited by CRFarnsworth, December 09, 2017 - 10:53 AM.
  • KennyP, Cvans, tiretrx and 1 other said thanks
#119 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted December 09, 2017 - 05:45 PM
Good thought!
  • Mark 149 J. said thank you
#120 tiretrx OFFLINE
tiretrx
  • 2,256 Thanks
  • 1,222 posts
Posted December 10, 2017 - 02:20 PM
If I'm understanding the question right, no I don't think that would matter, as the tranny and differential splines are free to move where necessary to align. Did I align them when I welded them up? Absolutely. I'm a bit anal with things like that. It just looks better to me  :smilewink:
  • KennyP, MFDAC, TomLGT195 and 1 other said thanks
