Sealed bearing in Sears spindles
16 replies to this topic
#1 bbuckler OFFLINE
bbuckler
  • 3,030 Thanks
  • 2,722 posts
Posted October 11, 2017 - 10:25 PM
Back on this topic I still can't find nothing to replace the 881R. So next question can I put sealed bearings in ?
  • Tecumseh power and 4APK.RU have said thanks
#2 Georgia SS OFFLINE
Georgia SS
  • 41 Thanks
  • 32 posts
Posted October 11, 2017 - 11:25 PM
Hi
This topic has been discussed many times on several forums, the answer to your question is no.
Hang In There
Jimmy
  • bbuckler said thank you
#3 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 9,725 Thanks
  • 5,418 posts
Posted October 12, 2017 - 06:08 AM
Here ya go:
https://www.m-and-d.com/AY-881R.html
  • KennyP and bbuckler have said thanks
#4 bbuckler OFFLINE
bbuckler
  • 3,030 Thanks
  • 2,722 posts
Posted October 12, 2017 - 06:40 AM
discontinued on that website
#5 John Arsenault OFFLINE
John Arsenault
  • 1,675 Thanks
  • 901 posts
Posted October 12, 2017 - 07:37 AM
Could it be this one?
https://www.walmart....9&wl13=&veh=sem
#6 John Arsenault OFFLINE
John Arsenault
  • 1,675 Thanks
  • 901 posts
Posted October 12, 2017 - 07:38 AM
Or this one
http://www.ebay.com/...hkAAOSw44BYfUin
#7 bbuckler OFFLINE
bbuckler
  • 3,030 Thanks
  • 2,722 posts
Posted October 12, 2017 - 09:41 AM
I got those just not the seals
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1,453 Thanks
  • 1,103 posts
Posted October 12, 2017 - 10:49 AM
I put sealed ball bearings in one of my sears spindles
  • EricFromPa and bbuckler have said thanks
#9 EricFromPa ONLINE
EricFromPa
  • 3,222 Thanks
  • 2,907 posts
Posted October 12, 2017 - 02:18 PM
They will work but they won't last nearly as long as a good tapered bearing set.
Let me look and see if I can find the seals again. I rebuilt the spindles on a Suburban 42 and 48" deck. If I remember correctly the Middle spindle had larger bearings and seals but i'll look them up again. This might take a while as they are very hard to find online. So just hang in there for a bit.
Edited by EricFromPa, October 12, 2017 - 02:18 PM.
#10 EricFromPa ONLINE
EricFromPa
  • 3,222 Thanks
  • 2,907 posts
Posted October 12, 2017 - 02:29 PM
Yep I am correct. Middle spindle shaft diameter is Slightly larger.
2 outer spindle shafts are 0.750 (19.05mm) (20mm ID seal)
center spindle shaft is 0.8658-0.8664 (22mm ID seal) according to several peoples measurements.
You need 2 seals with the following dimensions for the middle spindle. 22mm x 45mm x 7mm (ID x OD x Thickness)
And 4 seals for the outer spindles with the following dimensions.  20mm x 45mm x 7mm (ID x OD x Thickness)
2 x  Inner mandrel seals here. https://www.amazon.c...ding=UTF8&psc=1
4 x  Outer mandrel Seals here.  https://www.amazon.c...mm X 7mm 4 Pack
Bearings & Races
Outer Mandrels, )you will need 2 for each mandrel, 4 in total for the deck.)
4 x  Outer Mandrel Bearing & Race, Sears Part #1554H & 1553H, use Napa part # SME 704298
4 x  Metallic Grease Seal, Sears part #881R. is no longer available
Center Mandrel, (you will need 2 for each mandrel, 2 in total for the deck.)
2 x  Center Mandrel Bearing, Sears Part #888R Timkin/National part number LM12749
2 x  Center Mandrel Race ( Cup), Sears Part #9494H, Timkin/National part number LM12711
Bearing sets https://www.amazon.c...s/dp/B00UDM7X2I
2 x  Metallic Grease Seal, Sears part #882R is no longer available
Edited by EricFromPa, October 12, 2017 - 03:35 PM.
#11 bbuckler OFFLINE
bbuckler
  • 3,030 Thanks
  • 2,722 posts
Posted October 12, 2017 - 03:05 PM
This applies to:
Roper 42" deck Model #TT2131R
Roper 42" deck Model #TT728CR
Roper 48" deck Model #TT738CR
Sears 42" deck Model #917.253250
Sears 42" deck Model #917.253540
Sears 42" deck Model #917.553580
Sears 42" deck Model #917.253582
Sears 48" deck Model #917.253551
Sears 48" deck Model #917.253590
Sears 48" deck Model #917.253592
& Possibly Others.
Bearings & Races
Metallic Grease Seal, Sears part #881R. this part is available from Sears Parts Direct.
Center Mandrel Bearing, Sears Part #888R Use Timken Roller Bearing Part Number LM12749
Center Mandrel Race ( Cup), Sears Part #9494H, use Timken Roller Bearing part # LM12711
Metallic Grease Seal, Sears part #882R is no longer available, however it appears that part #881R can be used, but the center hole will need to be enlarged from 0.750" to 0.8658" it will then fit the shaft. ( I have not actually tried this, however using the bore diameter of the bearing, this measurement would be correct for the seal to fit over the shaft). On a complete deck overhaul, this would bring the required number of the 881R seals up to 6
NLA
#12 EricFromPa ONLINE
EricFromPa
  • 3,222 Thanks
  • 2,907 posts
Posted October 12, 2017 - 03:12 PM
Edited post look again lol.
Didn't take as long as it did the 1st time to find dimensions and seals. I have a bunch bookmarks saved for the junk I was working on, just had to dig through everything.
I can post bearing dimensions off of the Timkin part numbers if you need them. The seals were the hardest part to find dimensions for.
I had roughly $150 in bearings and seals when I did the 48" deck on the old SS14 4 or 5 years ago. But she ran super super Smooth and quiet as a mouse when it was back together. Definitely worth the money.  Looks like prices have dropped quite a bit since I redid my deck. I paid $8 + shipping for each seal.
Edited by EricFromPa, October 12, 2017 - 03:42 PM.
  • KennyP, bbuckler and Tecumseh power have said thanks
#13 bbuckler OFFLINE
bbuckler
  • 3,030 Thanks
  • 2,722 posts
Posted October 12, 2017 - 04:56 PM
It well worth $150 to get the Sears cutting modern mowers just can't handle the abuse.
  • EricFromPa said thank you
#14 Georgia SS OFFLINE
Georgia SS
  • 41 Thanks
  • 32 posts
Posted October 13, 2017 - 07:51 PM
Hi Eric
We would like details on how to use these seals and ball bearings on the suburban decks, I have restored 15 tractors and decks in the past six years and don't see how your idea would be successful, i savaged enough metal slingers to rebuild all I was working with, had a few extra spindles to rob.
Jimmy
#15 Alc OFFLINE
  • 6,421 Thanks
  • 7,230 posts
Posted October 14, 2017 - 05:33 AM
I'm confused , do these decks have tapered bearing from new ?
