belt size
3 replies to this topic
#1 wcrafter OFFLINE
wcrafter
  • 2 posts
Posted June 27, 2011 - 01:55 PM
Good Day to all, I have recently came into possession of a JD 110h with mower, snowblower and tiller. Got the tractor running good, now have mower deck belt & blades replaced.
What I want to know is what belt size between tractor and mower deck.
JD 110h ( serial # 106109m)
Mower deck ( serial # 108103m)
Any help would be greatly appreciated
Thanks Frank
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted June 27, 2011 - 02:12 PM
I know from what has been suggested before regarding belts used on John Deere garden tractors is to use John Deere belts. Surprisingly John Deere belts are not really any more expensive then buying other quality belts. If you go on jdparts dot com you can lookup all kinds of parts on their site. I don't know where you are located but maybe you have a John Deere dealer near you?
Welcome to GTtalk.
#3 wcrafter OFFLINE
wcrafter
  • 2 posts
Posted June 27, 2011 - 02:18 PM
Thanks , I thought that's what I would have to do.
BC , Canada, there is a JD dealer not to far from me.
Thanks
  • 14,730 Thanks
  • 15,470 posts
Posted June 27, 2011 - 02:47 PM
wcrafter, Welcome to GT talk.. If you have a 47" deck,the drive belt is part#M45998...used same belt on 39" deck. If you need to replace the blade to blade belt, 39" is part# M40223, 47" is part #41960... I hope this helps. As George stated above, you want to use a JD. belt, they have a different cross section they is special to JOHN DEERE...Good Luck...
  • wcrafter said thank you
