1968 JD 140 H1 lots of help needed
parts information
8 replies to this topic
#1 sobiepan OFFLINE
  • 1 Thanks
  • 1 posts
Posted October 09, 2017 - 10:49 AM
Good day,
I am new to the garden tractor life. I moved out of the city and found the H1 for sale for $400 and bought it because it has a snow plow and ran. I have spent the last few days replacing the throttle cable and choke cable as well as cleaning the carb and a few other things. The thing runs great. It starts right up and there is no smoke coming out of it. I can drive it around to a point...
Because I am new I am having a hard time understanding things though. not sure if I should create a new topic for each one but I thought having the thread in a single place will help me a lot.
...So what is my question?
When I run it downhill it runs fine, however, when i run it on a flat surface or uphill it seems to go for a minute then slow down then jerk forward for a minute then slow down then jerk... I am a guy that likes to start cheap and easy and work my way up. My thinking, which may be way off is that the transmission fluid or something is either way low or really bad. I was trying to find some material to read to figure out how to change it and change the filter if there is one. If anyone knows how to change the fluid please let me know! I am excited to own this and see if i can get it running properly.
#2 dodge trucker ONLINE
dodge trucker
  • 2,529 Thanks
  • 3,210 posts
Posted October 09, 2017 - 01:20 PM
something I see that doesn't make sense... I see that you are from Arizona. yet you bought a GT because it has a snow plow​..... is there a town in the Rust belt in some other state named Arizona?  like (maybe) Arizona, PA or something like that?
#3 KennyP ONLINE
  • 39,015 Thanks
  • 46,255 posts
Posted October 09, 2017 - 02:15 PM
HMMMMM? The IP shows California. And who in Arizona needs a snow plow?
#4 secondtry OFFLINE
  • 2,030 Thanks
  • 1,456 posts
Posted October 09, 2017 - 03:22 PM
Ok First welcome to the forum. I don't care if you use your snow plow for snow or to push over cactus. John Deere is very tight with their information so going to them is tough. A quick search on line tells me that the H series Deere used the Sunstrand 15 series typu U hydro. Evidently Sunstrand was bought out by SAUER DANFOSS. The information I am finding indicates there are several manuals on line free that may well help you. If you go to the top of this page third tab from the left is the manuals section. Click that tab then go down the resulting list to the transmission manuals. Click on that, the second page of that list you will find a lot of information on the Sunstrand 15 Good luck.  Don
#5 Kyocum OFFLINE
  • 299 Thanks
  • 424 posts
Posted October 09, 2017 - 03:23 PM
Next time you go out and drive it pull back on the hydraulic lift lever when moving forward and see if the problem goes away. I just bought a 1971 140 H3 which had the same problem. Come to find out someone had over tightened the hydro dump valve knob under the front of the seat.The actuator plate got bent enough so it wouldn't let the forward dump valve release all the way causing it to jerk the same way you describe. Re bent the plate and problem is gone.
#6 dodge trucker ONLINE
dodge trucker
  • 2,529 Thanks
  • 3,210 posts
Posted October 09, 2017 - 07:02 PM
Ok First welcome to the forum. I don't care if you use your snow plow for snow or to push over cactus.  Good luck.  Don
Hey now, I was trying to be funny. Not trying to scare anyone away....
  • secondtry said thank you
#7 Leonard VanCamp ONLINE
Leonard VanCamp
  • 579 Thanks
  • 430 posts
Posted October 09, 2017 - 07:50 PM
First two things to check is the hydro fluid and level. then check the relief valves like Kyocum said. Hydro fluid should either be type F transmission fluid or John Deere low viscosity hyguard. If that all checks out then things can start getting expensive, like worn out pump and such.
#8 Trav1s ONLINE
  • 3,390 Thanks
  • 4,422 posts
Posted October 10, 2017 - 05:59 AM
Deere used two different pump/rear ends in the 140.  A tractor serial number would help confirm which one you have.  I would also suggest hunting down a service manual.  The old style rear end is used in machines 00000 -30000 (1968-1970) and the new style pump/axle was used 30001 + (1971 -1974 and shared with the 120.)
#9 Dayton_King ONLINE
  • 1,376 Thanks
  • 1,100 posts
Posted October 24, 2017 - 08:59 PM
Flagstaff and northern Arizona does get snow
Also tagged with one or more of these keywords: parts, information
