New (almost) super 12
33 replies to this topic
#16 MH81 OFFLINE
Posted June 30, 2011 - 07:06 AM
Any signs someone had been in it before? That's what happened to Ryans engine, someone didn't tighten the mains and one side loosened up. The splash oiler was touching the case when you turned it over.
Time to open her up.
#17 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted June 30, 2011 - 02:06 PM
I am gonna get another engine from KC hopefully. So I wont have to open it up
#18 MH81 OFFLINE
Posted June 30, 2011 - 06:11 PM
Casey has extra engines??? When did that happen? :bigrofl:
#19 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted June 30, 2011 - 08:41 PM
haha
#20 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted July 04, 2011 - 08:46 AM
NICE find and save on your new to you Sears! It is in way to good of condition to become a parts tractor. Hope you get the engine problem fixed and up and running again.
#21 Bill56 OFFLINE
  • 842 Thanks
  • 2,179 posts
Posted July 04, 2011 - 09:30 AM
Nice find... a great looking Sears!!
#22 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 04, 2011 - 09:39 PM
This tractor will be coming with me to the plowday if I make it out there. Hopefully I will have a 3pt by the time that comes around.
#23 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 04, 2011 - 09:58 PM
I can always spare a techumseh lol
#24 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted July 05, 2011 - 11:47 AM
Yes, I was looking at it for parts... but the thing was.... I didn't get a chance to see it and had no info on condition.
#25 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 13, 2011 - 10:22 PM
Well, I tore apart the engine the other day. The rod endcap and split in 2. I am suprissed it didnt wreck anything else lol.
#26 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 25, 2011 - 10:30 PM
well, now its time for an update. I got my new engine today. As I said it was out of a bolens so I didnt know what to suspect. When the engine came I found out about the oil drain on the bottom of the block, and my super 12 having a solid frame I couldnt use that engine. So, I pulled it all apart and took the piston and connecting rod out and threw it in the supers engine. I got it all back together and hit the key and it was fire every so often. It seemed like the timing was off so I opened it up and wella, the timing was WAY off. So I got it all sorted out and it ran for a few seconds then quPhoto0161.jpg
#27 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted July 25, 2011 - 11:13 PM
That's more tore down than I expected to see, glad you are getting some use out of that Tecumseh I had.
#28 MH81 OFFLINE
Posted July 26, 2011 - 01:46 AM
Disconnect the wire from the SSI. Hold onto it while you crank & you should get a pulsing "tingle". Not bad, its not spark voltage. If not, let us know.
As for the gaps, which SSI do you have? Does the flywheel have pins on it?
#29 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 26, 2011 - 10:35 AM
its under the flywheel. A few people told me to turn it all the way to the left and tighten it down
#30 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 97 Thanks
  • 348 posts
Posted July 26, 2011 - 02:37 PM
Its alive once again!
