Craftsman scoop bucket thing
19 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted October 01, 2017 - 08:38 PM
Looking into getting one of these things, handbombing the chicken pen out sucks. I'll probably find more uses for it after
Now that I think, this should fit on my mom's old cub cadet ltx1045 if I track it down...
Edited by Greasy6020, October 01, 2017 - 08:40 PM.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted October 01, 2017 - 08:43 PM
That it will tear up the front axle of that Cub in about 30 minutes.
  • Gtractor and Greasy6020 have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,310 Thanks
  • 4,948 posts
Posted October 01, 2017 - 09:07 PM
ditch fill
  • Greasy6020 said thank you
#4 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted October 01, 2017 - 09:53 PM
ditch fill
You're saying the scoop thing is ditch fill?
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,310 Thanks
  • 4,948 posts
Posted October 01, 2017 - 10:24 PM
pretty much.
If you really take it easy with the scoop it should be OK but they were made to sell,  not to actually use.
  • boyscout862 and Greasy6020 have said thanks
#6 secondtry OFFLINE
secondtry
  • 1,857 Thanks
  • 1,373 posts
Posted October 01, 2017 - 11:19 PM
    I found one of those at a G Sale, $50. Mounted it on a craftsman 3000. Had a pile of dirt that I had moved close to the house with my 8n front loader. Needed to move that dirt into an area with restricted access. I used the scoop to move the dirt. Pushing in to the pile I could get about as much dirt as I could lift with the operating handles into the scoop. To make it work I at times had to operate both handles at the same time. the bucket tilt would not lock in if the bucket was not lifted with the other handle. When I had the lift adjusted to scrape the top of the ground the dump function was difficult to accomplish. Attempting to back blade as you can with a front loader is a two handed operation for a contortionist and not very effective. But it can be accomplished. Spent about an hour moving a yard of dirt and don't think i was much more sore than I would have been using a wheelbarrow. All in all I am not unhappy with my $50 investment. I have a lot of rocks on my property and and find it -good for moving them to a rock pile. All this said for the chicken pen a back blade would likely be more effective especially if you are using a bedding material. once the material has been loosened up the scoop might be used to scoop and transport it for disposal. you would need a wall to push it up against to force it into the bucket. With time patience and planning they can be a useful implement.  If you are short on any one of those three requirements, or are thinking front loader you are wasting time and money.  Don
  • KennyP, boyscout862, TomLGT195 and 2 others have said thanks
#7 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted October 01, 2017 - 11:29 PM
Have to agree on this one.  They are pretty much worthless. They only lift about 3 inches and they do not dump very well with a full load.
Here watch this. lol
Edited by EricFromPa, October 01, 2017 - 11:32 PM.
  • Cvans and Greasy6020 have said thanks
#8 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted October 02, 2017 - 03:59 AM
And they are called a "Johnny Bucket", although Johnny Bucket may be a brand name.
#9 poncho62 OFFLINE
poncho62
  • 1,725 Thanks
  • 1,655 posts
Posted October 02, 2017 - 05:19 AM
I just finished building something similar. I made the bucket smaller than the one you show. It lifts with the hydraulic deck lift, wont lift a lot, but is useful....Built from scrap metal I had around. So far so good. Unloaded this trailer of manure with it
Edited by poncho62, October 02, 2017 - 06:00 AM.
  • Alc, KennyP, Cvans and 2 others have said thanks
#10 KennyP ONLINE
  • 38,227 Thanks
  • 45,861 posts
Posted October 02, 2017 - 07:22 AM
I've thought about building one. Sure would be handy to move dirt/gravel around.
  • EricFromPa and Greasy6020 have said thanks
#11 boyscout862 ONLINE
  • 12,830 Thanks
  • 9,158 posts
Posted October 02, 2017 - 07:25 AM
A Jonny Bucket is a much better built and designed unit. I have a home made unit that is made for the back of my ACs and Simplicitys. The plans for it are on  www.simpletractors.net  . I dont use mine because turning my neck gets painfull real quick. I intend to adapt it to the front someday. Good Luck, Rick
Here is what we have  http://gardentractor...t-bucket-plans/
Edited by boyscout862, October 02, 2017 - 07:29 AM.
  • Alc and Greasy6020 have said thanks
#12 toppop52 OFFLINE
toppop52
  • 5,242 Thanks
  • 4,752 posts
Posted October 02, 2017 - 08:22 AM
I had one of the Sears units, bought it for $75 still in the boxes. I threw most of it away and adapted a longer mount to raise to 36” and used a winch to raise and lower it, had a rope dump. The Bucket itself is ok for a couple hundred pounds.
Edited by toppop52, October 02, 2017 - 08:24 AM.
  • boyscout862, Greasy6020 and secondtry have said thanks
#13 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted October 02, 2017 - 03:30 PM
Got an old Sears suburban plow laying around?  Would be a good start on a home made johnny bucket with the way the plow lifts straight up. They don't tilt back and up like most of the other brands plows do.
#14 lrhredjb ONLINE
lrhredjb
  • 690 Thanks
  • 568 posts
Posted October 02, 2017 - 04:41 PM
Cool Beans!
  • toppop52 said thank you
#15 secondtry OFFLINE
secondtry
  • 1,857 Thanks
  • 1,373 posts
Posted October 02, 2017 - 05:01 PM
    Got plans/pictures/drawings/more information? Don
