Bolens 12bb01, is an engine swap possible or fix?
2 replies to this topic
#1 nkaust OFFLINE
nkaust
  • 79 Thanks
  • 97 posts
Posted September 27, 2017 - 08:46 PM
As the titles says i was wondering if this was possible to swap a predator 3hp. the biggest concern is with gear reduction and shaft size of the current engine, which i guess i should have got the engine info. i will tomorrow , the current engine is a briggs but it smokes, the carb is a real pain in the rear and it doesn't have recoil start
thanks
cody
#2 Bob White12 OFFLINE
Bob White12
  • 134 Thanks
  • 132 posts
Posted September 27, 2017 - 09:38 PM
i bet it would be fine you might want to check the RPM ratings though. I don't know much about these tractors though so i'm not really the person to ask. are they belt driven? you can change pully size.
#3 DougT OFFLINE
DougT
    Dog Approved
  • 6,927 Thanks
  • 4,996 posts
Posted September 27, 2017 - 10:09 PM
Cody, one of the biggest questions is what are you planning on doing with the tractor. The original engine is a 6 to 1 reduction so you would have to do some major pulley changes or get an engine with a reduction. If this is just a working machine, it would be alright. If you are wanting to keep it as a collectible, it would ruin the value. Parts should be available to rebuild the Briggs.
  • Bolens 1000 said thank you
