Predator V twins?
10 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,627 Thanks
  • 1,495 posts
Posted September 27, 2017 - 04:37 PM
Anyone ever done a repower with a predator twin from harbour freight?
I'm looking into repower a Massey 14 due having a wicked knock just turning over with the starter. Coil also was hot enough there was some "blue air" after dad grabbed it.
#2 EricFromPa ONLINE
EricFromPa
  • 4,174 Thanks
  • 3,352 posts
Posted September 27, 2017 - 05:12 PM
They used to have pretty severe governor and carburetor issues but i don't know how they are now.  Do not get one with the EPA Emission Carb on it. They run horribly lean.
  • Greasy6020 said thank you
#3 chieffan ONLINE
  • 11,345 Thanks
  • 7,106 posts
Posted September 27, 2017 - 05:39 PM
I have a Bolens re-power with a Greyhound 11hp in it.  This is right before the Predator line came out.  Seem to be a good strong running engine.  May blow up the next time I fire it up - who knows?
#4 Greasy6020 ONLINE
Greasy6020
  • 1,627 Thanks
  • 1,495 posts
Posted September 27, 2017 - 05:47 PM
What kind of governor issues?
fiddling with the carb adjustments to make it run proper, instead of too lean would solve that wouldn't it?
#5 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted September 27, 2017 - 06:53 PM
I ran away from the predator engines, or the carroll stream , lifan etc. I have done enough research to tell me not to throw my money away on disposable engines. I have helped my neighbor with a few of them and was not at all impressed with the build quality. Parts Pfffft , there is no support on those engines , the gaskets melt in your hand. When brand new they do fire up and work well but I would have more faith in fixing your old engine.
The massey 14 is a kohler right?
#6 James Bosma OFFLINE
James Bosma
  • 1,478 Thanks
  • 729 posts
Posted September 27, 2017 - 09:27 PM
Yes Massey 14 has a Kohler K321
Why not find another K321 or K341
Then it be real easy
They go for around 200 in my area
#7 EricFromPa ONLINE
EricFromPa
  • 4,174 Thanks
  • 3,352 posts
Posted September 27, 2017 - 10:49 PM
Plastic governor gear flying apart and the carbs have fixed non-adjustable jets. Did some digging and they did address the governor gear issue but there still using the same carbs.
The carbs are setup for strict EPA standards and thus do not give the engine enough fuel to run properly.
You'll be ok if you do away with the big EPA emission muffler and slightly enlarge the jets. They have some sort of catalytic converter built into the muffler and the carb is jetted to run lean to keep the converter hot and clean.
Better yet, get an aftermarket honda gx670 carburetor for around $50 on ebay and put it on a 670 Predator. They still have fixed main jets but fully adjustable idle jets. They are not EPA regulated.
https://www.ebay.com...uretor&_sacat=0
Edited by EricFromPa, September 27, 2017 - 10:55 PM.
  • Cvans, Greasy6020 and Mark 149 J. have said thanks
#8 Greasy6020 ONLINE
Greasy6020
  • 1,627 Thanks
  • 1,495 posts
Posted September 28, 2017 - 06:43 AM
I understand... thing is the kohler has a wicked knock. Only reason I discovered this was because I was trying to get it to start the other day.
That's why I was looking into the predator vtwins
#9 John Arsenault OFFLINE
John Arsenault
  • 2,919 Thanks
  • 1,321 posts
Posted September 28, 2017 - 07:07 AM
I recently gave up on a few HH120's only because parts are not available for them. I have two blocks that need an overbore but finding over sized pistons is not an easy or cheap task. out of 3 engines I have one operational carburetor and to pay 100 plus for a 50 year old rebuilt one was not going to happen. Also the ignition systems on tecumseh is obsolete  but the option of buying 50 year old plus electronic for another 150.00 or so was again not going to happen.
Kohler on the other hand you can still get stuff for and the cost is reasonable. I have a 12 hp kohler I rebuilt and its awesome. Wish it could have worked out the same for the tecumseh's.
#10 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted September 29, 2017 - 11:22 AM
Rebiulding the K series Kohlers are getting harder and harder... mostly only aftermarket stuff now..
I have a Predator engine on my 2" pump and it runs flawless! And has now for 3 years.. last year it got a workout pumping water from the brook during the drought..
#11 dropped82 ONLINE
dropped82
    Nut Case
  • 2,740 Thanks
  • 1,905 posts
Posted September 29, 2017 - 03:31 PM
You could rebuild that Kohler a couple times, with the money and time it'll take to put that Predator in there. Plus you'll still have an original beast of a machine.
  • Greasy6020 and pryan05 have said thanks
