Is this hole supposed to be in the float Bowl
8 replies to this topic
#1 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted September 27, 2017 - 02:19 PM
I'm doing this on my phone so bear with me.
I'm working on my gt5000 Craftsman
It will not run without the choke on when I pulled the carburetor apart I found this little hole right there next to the half moon scratches in the side of the bowl
It does not appear to be a factory hole so I'm wondering if this is why the thing will not run.
When I spray carburetor cleaner down that little hose it sprays out right there from that hole
  • Craig. said thank you
#2 EricFromPa OFFLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted September 27, 2017 - 02:41 PM
Yep supposed to be there. They are for the accelerator pump. They call it a Bleed jet.
Here check this out. Lots of holes that need cleaning. I counted 34 holes. That's alot of possible clogs.
http://outdoorpoweri..._nikki_carb.asp
Edited by EricFromPa, September 27, 2017 - 02:51 PM.
  • Alc, Craig., KennyP and 4 others have said thanks
#3 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted September 27, 2017 - 04:11 PM
Thanks I have an ultrasonic cleaner on the way I guess I know what the first thing in it is going to be
  • Alc, Craig., EricFromPa and 1 other said thanks
#4 EricFromPa OFFLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted September 27, 2017 - 05:06 PM
Is it a heated one?
I want one of those so bad. I hand clean every carb I have to work on. It takes hours, some times a couple days to get one perfect depending on how bad it is.
  • Craig. and Mark 149 J. have said thanks
#5 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted September 27, 2017 - 06:08 PM
This one ran perfect until I loaned it to somebody and they put bad gas in it
  • Craig. and KennyP have said thanks
#6 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted September 27, 2017 - 06:17 PM
Yes it is heated. 3.2l capacity. Only thing it doesn't have is a drain.
#7 KennyP ONLINE
  • 38,262 Thanks
  • 45,876 posts
Posted September 27, 2017 - 06:43 PM
Where'd you get it?
#8 olcowhand ONLINE
  • 41,070 Thanks
  • 31,392 posts
Posted September 27, 2017 - 06:47 PM
I have one from Harbor freight and it works very well!
  • Craig., KennyP and Mark 149 J. have said thanks
#9 UncleWillie OFFLINE
  • 15,663 Thanks
  • 8,758 posts
Posted September 27, 2017 - 09:46 PM
Where'd you get it?
Amazon.
Harbor Freight didn't have one big enough for me to get the things I need in it.
