1960s Simplicity disc
5 replies to this topic
#1 Z71 Sierra OFFLINE
Z71 Sierra
  • 235 Thanks
  • 129 posts
Posted September 26, 2017 - 06:45 AM
I saw this disc for sale locally. Im unsure if it will work with a sleeve hitch on my Squire 12. Anyone kmow if this will work?Screenshot_20170926-065838.png disc_harrow_pg8.jpg
#2 Talntedmrgreen OFFLINE
  • 3,282 Thanks
  • 2,313 posts
Posted September 26, 2017 - 07:23 AM
Yes, it will work.  The Simplicity sleeve hitch tube was taller than Brinly's sleeve hitch and attachment yoke's.  So, any Simplicity sleeve hitch implements will fit a Brinly style sleeve hitch without issue.  There will be a little gap, so you may need a longer than normal pin.  Here's that disc with the taller Simplcity sleeve hitch.  Using a typical sleeve hitch you would see about a half inch of the pin where it passes through the hitch.
  • boyscout862, KC9KAS and Z71 Sierra have said thanks
#3 Greasy6020 ONLINE
Greasy6020
  • 1,590 Thanks
  • 1,471 posts
Posted September 26, 2017 - 07:44 AM
I'd do go for it!
#4 Z71 Sierra OFFLINE
Z71 Sierra
  • 235 Thanks
  • 129 posts
Posted September 26, 2017 - 09:40 AM
#5 Z71 Sierra OFFLINE
Z71 Sierra
  • 235 Thanks
  • 129 posts
Maybe it is. The steel plate is pretty wide. I dont have anywhere to hook a chain up to. Is that a problem?20170923_145851.jpg
Edited by Z71 Sierra, September 26, 2017 - 09:54 AM.
#6 MiCarl ONLINE
MiCarl
  • 2,163 Thanks
  • 1,106 posts
Posted September 26, 2017 - 09:58 AM
The problem you're going to have is that Simplicity hitch on the disc is narrow.  On a Simplicity hitch with chain the lift arm/chain limit the implement swinging side to side.  When you lift the implement it will swing and eventually bang into something causing bends and breaks.
You can keep it from doing that by putting a tether chain (or rope) on each side attached back near the pivot point on the tractor hitch.  Then you'll be in business.
Edited by MiCarl, September 26, 2017 - 09:59 AM.
  • Doug E., Z71 Sierra and Mustard Tiger have said thanks
