what make is this?
12 replies to this topic
#1 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 11:07 AM
  • 14,896 Thanks
  • 15,517 posts
Posted June 26, 2011 - 11:12 AM
That is a Wheel Horse blade that someone has modified. not sure what they had it mounted on, but It's a W.H. blade for sure..
The tag should have a couple of rows of numbers, which will be model and serial numbers. Post them if you can read them
  • drbish said thank you
#3 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 12:00 PM
the two rows of numbers are 6-4113 6,743024
  • 14,896 Thanks
  • 15,517 posts
Posted June 26, 2011 - 01:00 PM
I can't find 6-4113, but found 6-4111, which is a 1968 42" front dozer blade. I will continue to look into it for you.
#5 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 01:29 PM
i have found the same thing,this blade measures 54 inches
#6 Texas Deere and Horse OFFLINE
  • 14,896 Thanks
  • 15,517 posts
Posted June 26, 2011 - 01:40 PM
let me re-check my info.
#7 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 01:51 PM
i seen a 54 in on a search engine and it was on a d160
#8 Texas Deere and Horse OFFLINE
  • 14,896 Thanks
  • 15,517 posts
Posted June 26, 2011 - 01:55 PM
Is the tag on the frame or blade?
#9 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 02:03 PM
the tag was on the frame,the previos owner pried it of while i was their to get a better look at it if you look at the pics you can see where it was located.it is a more red where it was located
#10 Texas Deere and Horse OFFLINE
  • 14,896 Thanks
  • 15,517 posts
Posted June 26, 2011 - 02:51 PM
Well, It could be that someone combined pieces to make up a plow. That would explain the 54" blade on a 42" frame.
#11 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted June 26, 2011 - 07:07 PM
thanks for the info,neighbor was going to scrap it.so i gave him a little cash for it.I figured i could take to a show and let someone,that could use it buy it,since i have no use for it,hate to see it scrapped
#12 GWest OFFLINE
GWest
  • 558 Thanks
  • 511 posts
Posted June 26, 2011 - 08:16 PM
The 6-4113 was sold 1970-73 and is the completeing package for the 6-9621 or 6-9622 42" blade Fits long & short frame tractors except Lawn Rangers and mid-engine models.
The 6-4113 was also used with 6-9611 or 6-9612 54" blade on the GT-14.
This is a 1971 model determined by the 6 following the 6-4113. Subtract 5 from the number 6-5=1971.
Have seen 1971 serial numbers range from 635967 to 891279.
Garry
  • caseguy, KennyP and drbish have said thanks
#13 KennyP ONLINE
  • 41,453 Thanks
  • 47,382 posts
Posted June 27, 2011 - 05:48 AM
Good info, Garry. Thanks for posting it.
