Bush Hog D4-7 is home with it's brother.
35 replies to this topic
#31 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 23, 2011 - 04:43 PM
I figured I would post another update. The D4-7 is a non runner for now until I get a chance to yank the motor and go over it. I would like to redo the valves and check the timing. I just can't get it to run right and I have never had one act the way this one does. I have had the carb apart several times thinking it is the float but it isn't.
#32 MH81 OFFLINE
Posted August 23, 2011 - 05:39 PM
Are you thinking compression or a sticky valve?
#33 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 23, 2011 - 05:43 PM
I do think sticky valve or possible slop in the flywheel key. Once in a while I can get it to pop off and run alright and then the next time it keeps choking on itself.
#34 olcowhand ONLINE
  • 40,332 Thanks
  • 31,168 posts
Posted August 23, 2011 - 05:54 PM
Not sure why, but I've had more sticky valves with Wisconsin's than any other make.
#35 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted August 23, 2011 - 05:57 PM
Its been just the Oppostite with me.... I only had a stuck valve 2 times on a Wisconsin.
#36 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted August 23, 2011 - 06:00 PM
I am going to get a gasket kit for both the Wisconsin S7D and the S10 and also get a set of rings for both and hone the cylinders. I will replace anything else that isn't in spec as well. Part of me wants to restore them but then part of me likes them the way they are. I just know I want them running good. The D4-10 runs awesome and idles perfect, just smokes.
