Project Cub 2182
25 replies to this topic
#1 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 12:56 PM
Hey guys
Wanted to share this build thread with you.  First ground up Cub build ive ever done so Im open to comments, advice or opinions.  Ive already took one fellas advice and bought the rear axle/frame stiffeners.  i actually started this project back in Feb but had to get off of it for awhile to get caught up on some other things.  Hopefully now i will be able to get this thing wrapped up.  Here are a few pictures to show where i started and where im currently at.
Thanks guys
This is the day i bought it
Edited by KDB, September 21, 2017 - 01:42 PM.
  • olcowhand, KennyP, boyscout862 and 1 other said thanks
#2 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 01:38 PM
the tractor had little over 1000 hrs on it and had been neglected.  i got it home, changed the oil, cleaned the carb and added fresh gas and noticed that when it warmed up it had a pretty loud knock mid range that wasnt heard at all cold.  I had already spent a few minutes cruising around the yard and fell in love w it, so i decided to tear into the engine.  and if i was gonna go that far with it, i might as well go thru with complete resto.   crazy thing is when i tore into the engine, i found that the first 3 of the 4 main bearings had spun and yet it still had really good oil pressure.  before i took the engine off the tractor i could take the front pulley and shake it around a good 1/16th any angle i pulled it.  Hard to believe it even ran at all.
Edited by KDB, September 21, 2017 - 01:40 PM.
  • olcowhand, boyscout862 and Mark 149 J. have said thanks
#3 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 01:46 PM
here are a few disassembly pics of tractor
  • olcowhand and Mark 149 J. have said thanks
#4 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 01:51 PM
cleaning and painting
Edited by KDB, September 21, 2017 - 01:59 PM.
#5 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 01:53 PM
parts back from powdercoating
#6 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 01:56 PM
rolling frame - finally getting it back together
#7 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 02:02 PM
building the engine...
  • olcowhand, KennyP, CRFarnsworth and 2 others have said thanks
#8 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 02:05 PM
this is where im at so far...  hopefully i can set the engine back on frame this weekend.
#9 KennyP ONLINE
  • 40,011 Thanks
  • 46,722 posts
Posted September 21, 2017 - 02:22 PM
Wow! Glad you interceded on the engine when you did! That should last you a number of years when you get done!
  • boyscout862 and KDB have said thanks
#10 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 02:34 PM
i sure hope so!   my 10 year old has already called dibs on it    haha
#11 EricR OFFLINE
EricR
  • 709 Thanks
  • 427 posts
Posted September 21, 2017 - 03:45 PM
Very nice, wonder what made the engine fail in the first place!!!
#12 nkaust OFFLINE
nkaust
  • 79 Thanks
  • 97 posts
Posted September 21, 2017 - 07:57 PM
well im no expert but it looks like you pretty much got this in the bag lol, but the only advice i can say is take your time, you will be more satisfied with it when its done
#13 olcowhand ONLINE
  • 42,289 Thanks
  • 31,764 posts
Posted September 21, 2017 - 08:11 PM
Man you did a nice job!  That engine looks VERY nice!!
#14 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 08:49 PM
Wondered the same thing Maybe low oil situation? It had a pretty good leak from timing cover seal. I got the feelin from the guy i bought it from he didn't let too much concern him. Haha
#15 KDB OFFLINE
KDB
  • 39 Thanks
  • 29 posts
Posted September 21, 2017 - 08:56 PM
Thanks for the kind words. I try to research and read a lot but there is still a lot ima need help with. Like the leaking power steering sector. I'm seeing their painful to rebuild
