Simplicity disk for walk behind tractor (butchered by previous owner)
5 replies to this topic
#1 Greasy6020 ONLINE
Greasy6020
  • 1,590 Thanks
  • 1,471 posts
Posted September 20, 2017 - 09:23 PM
I have a simplicity disk, it's kinda butchered... tongue was modified so previous owner could pull behind atv etc, has rack for weight (say a log or large pipe) and it's in need of new bearings.
Id like to put a set of notched disk plates on there, so I can work the ground better. Currently it doesn't do much. At one point I had a stout chunk of poplar on it, along with my old man... he's uh, not skinny.
Does anyone know if there's a place I could get proper sized disk plates?
Now for the bearings. What sort of wood should I use to make the new bearings from? Any designs/plans for the bearings?
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 5,052 Thanks
  • 2,233 posts
Posted September 20, 2017 - 09:41 PM
 Rock Maple.
I saw an ad for wood bearings not too long ago.
Do a search and I'm sure you'll find something.    Rick
  • boyscout862 and Greasy6020 have said thanks
#3 Alc ONLINE
  • 7,129 Thanks
  • 7,532 posts
Posted September 21, 2017 - 05:26 AM
Since it's been as you said " butchered "  could you use a plasma cutter or find someone to notch the discs you have ?
  • Greasy6020 said thank you
#4 Greasy6020 ONLINE
Greasy6020
  • 1,590 Thanks
  • 1,471 posts
Posted September 21, 2017 - 07:40 AM
i could try that, honestly I never even thought of thy!
#5 chieffan ONLINE
  • 10,951 Thanks
  • 6,944 posts
Posted September 21, 2017 - 12:42 PM
Plow first then disk it and it will work much better.  Disk were not made to turn virgin ground.
#6 Greasy6020 ONLINE
Greasy6020
  • 1,590 Thanks
  • 1,471 posts
Posted September 21, 2017 - 03:12 PM
Even then it doesn't do much of anything
