Montgomery Wards Plow-Trac rebuild
7 replies to this topic
#1 Gimpydog OFFLINE
Gimpydog
  • 1 Thanks
  • 3 posts
Posted September 18, 2017 - 07:07 PM
I recently found a Montgomery Wards Plow-Trac Article #89-1278 SIM 990136A barn fresh with its 42 inch WDM-1393 serial # 85x-85 blade.The original Clinton engine is mostly there but likely has a broken connecting rod. Anyone need parts! I'm looking to take the tractor apart, paint it then reassemble it for use as a snow plow. Can the gear boxes be rebuilt and if so who sells parts? The transmission seems to have all three speeds, reverse and Hi/Low functioning. I was going to pop a tacky Honda 5hp on it so it will be functional. Thoughts or advise?
  • Gtractor said thank you
#2 B10Dave ONLINE
B10Dave
  • 764 Thanks
  • 347 posts
Posted September 18, 2017 - 11:15 PM
If gearbox is functioning in all gears and the planetary hi/lo is working I wouldn't mess with it. They are a strong gearbox and don't usually give any trouble. I have a newer 5hp Briggs on mine that works very well. It should be a good snowplow if you have wheel weights and/or chains for it. Have fun....Dave
#3 Gimpydog OFFLINE
Gimpydog
  • 1 Thanks
  • 3 posts
Posted September 19, 2017 - 01:15 AM
The grease is really old and the seals that are visible shot. I assume they were designed to run fully packed with grease as I can find no oil ports. The paint is also missing in many places therefore I'd like to get it powder coated. I was going to straighten the bent handles then paint it red with white wheels to match the Honda. Sort of a contemporary trade off. It appears to have been orange. Do you know where I can find the major seals?
#4 Gimpydog OFFLINE
Gimpydog
  • 1 Thanks
  • 3 posts
Posted September 19, 2017 - 01:38 AM
The particularly disassembled tractor with much of the grease coated pig poo removed. The one ring seal just hangs loosely. That can't be right. The grease is so old I doubt I can force enough new grease in. With a good deal of effort I was about to free up the shift selector arm. All the gears appear to function
#5 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted September 19, 2017 - 05:32 AM
Always thought the 1278 was a Simplicity model FC number 990129 that used a Kohler 4hp engine.
Perhaps it left Simplicity without an engine using number 990136 and Wards added the Clinton engine.
http://gardentractor...vb-1958-om-ipl/
Garry
#6 boyscout862 ONLINE
  • 12,558 Thanks
  • 9,048 posts
Posted September 19, 2017 - 06:59 AM
Welcome to GTT. The "SIM" in the model number indecates that it is Simplicity made. Check our Manuals Section for the manuals to your tractor and engine. I adopted a 5 hp B&S to mine 30 years ago, using two 1/2" x 1" x 8" adapters that I made and threaded.
The seals are probably "off the shelf" standard sizes that you can get at a NAPA. Be carefull, take pics as you dissassemble, and most important, have fun. Good Luck, Rick
#7 DanielG OFFLINE
DanielG
  • 56 Thanks
  • 60 posts
Posted December 09, 2017 - 09:13 AM
new member and just found your post wanted to add my two cents worth I have a wards garden trac and really like it we used a wiscon bkn it works great pretty easy to adapt any motor enjoy your project
#8 twowheeler63 OFFLINE
twowheeler63
  • 18 Thanks
  • 19 posts
Posted December 13, 2017 - 08:05 AM
I'm not sure if this helps, but I have a parts breakdown for an FB, with handwritten part numbers, I assume from a mechanic.
It has a seal number of 8051031, shown for the axle seal. This however, isn't shown on the FC parts breakdown, and there is a transition from the old numbering system to the new system, that must have been implemented between the FB and FC.
