2017 Fall "Ball Hollow Plow Days" CANCELED
49 replies to this topic
#31 Texas Deere and Horse OFFLINE
  • 14,862 Thanks
  • 15,511 posts
Posted October 11, 2017 - 07:13 PM
I'm going to try to make it, but things are going to have improve around here first
  • olcowhand, Craig., KennyP and 1 other said thanks
#32 olcowhand ONLINE
  • 42,301 Thanks
  • 31,772 posts
Posted October 11, 2017 - 07:15 PM
I'd certainly understand you not being able to make the trip Brian.
  • Grumpy, Texas Deere and Horse, Craig. and 1 other said thanks
#33 Grumpy ONLINE
Grumpy
  • 732 Thanks
  • 619 posts
Posted October 12, 2017 - 08:55 AM
Looking forward to seeing you again along with everyone else.
  • olcowhand, Craig. and dropped82 have said thanks
#34 CRFarnsworth ONLINE
CRFarnsworth
  • 4,954 Thanks
  • 2,211 posts
Posted October 14, 2017 - 04:45 PM
I've got two tractors ready to go.   I know that one of them is plowing real nice.  At least  it was in my brothers garden in some "chocolate" dirt.  We'll see what they do in that Kentucky clay.     Rick
  • olcowhand, Craig. and SupplySergeant have said thanks
#35 olcowhand ONLINE
  • 42,301 Thanks
  • 31,772 posts
Posted October 14, 2017 - 06:43 PM
I am beginning to get concerned with the soybean harvest.  Steve is just beginning harvesting beans, and he's a long way from getting to my place, as it was his last planting.  He didn't get to harvest any ground last week at all due to rain, and he's behind.  Just have to wait and see.
  • Craig. and SupplySergeant have said thanks
#36 CRFarnsworth ONLINE
CRFarnsworth
  • 4,954 Thanks
  • 2,211 posts
Posted October 14, 2017 - 06:50 PM
HMMM,  It could be a might dusty tailgating a combine through your field.   :D   Rick
  • olcowhand, Craig., KennyP and 2 others have said thanks
#37 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,919 Thanks
  • 1,062 posts
Posted October 18, 2017 - 02:57 PM
I just found out my Dad is coming up on the 4th. Thought it was going to be no plow day, then he said he'd like to come! So, still planning to be there, assuming the beans are gone!
Does that combine by the field still run? Maybe Eric could harvest, instead of plow, on Friday!
Edited by SupplySergeant, October 18, 2017 - 02:58 PM.
  • olcowhand, limebuzz, KennyP and 1 other said thanks
#38 olcowhand ONLINE
  • 42,301 Thanks
  • 31,772 posts
Posted October 18, 2017 - 04:49 PM
Steve likes a lot of beans getting to my place, so we'll just have to wait and see!  Went to PT this morning and got my neck stretched, and my arms in every direction.  Pulled things that haven't been pulled that far in a loooong time.  I had a headache when I woke up, but after the neck stretching, it went from a mild one to a nasty old headache!  Went on into work, loaded fertilizer and delivered 3 loads.  One load went back to the area we went before, but a few miles further....60 miles from the store.  Made it through work ok, but had a bad surprise at quitting time.   My brake light came on this morning and I knew my brake fluid was low.  I topped it off before coming home after work, but had to stop for a loaf of bread.   Saw brake fluid dripping onto the parking lot, so limped on home, prepared to use my emergency brake if need be.  Still had some brake, but very weak by the time I got home.  Looks like the brake line corroded behind a mounting block on the rear end tube.  I'll put it on the lift in a bit, and if I can do a temp repair on it I will.  Otherwise I'll take Dad's truck to work tomorrow.  I've been needing to rotate my tires, so I'll get a new set of rear brake shoes, both new rear brake cylinders, and whatever brake lines needed to do things right over the weekend.  My RR brake cylinder has leaked ever so slightly for a while now anyway, so I'll do both sides while I'm at it.
  And I thought I'd come home and kick back!  :(   Nope!
  • KennyP and SupplySergeant have said thanks
#39 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted October 18, 2017 - 05:29 PM
So are you taller now? LOL I hate headaches, don't get them often. More issues with the neck not turning like it should.
Sorry to hear of the brake fluid escaping captivity. That's not a good situation. Hope all goes well with the fix there!
  • olcowhand and SupplySergeant have said thanks
#40 Grumpy ONLINE
Grumpy
  • 732 Thanks
  • 619 posts
Posted October 18, 2017 - 06:55 PM
Sounds like I need to invent some brake fluid stop leak.
  • olcowhand said thank you
#41 dropped82 OFFLINE
dropped82
    Nut Case
  • 2,633 Thanks
  • 1,869 posts
Posted October 18, 2017 - 07:39 PM
Don't worry, I'll leave a few rows for you on Saturday. I think I'll even have my 140 down there. It won't be completely done but good enough to turn some dirt.
#42 colobob OFFLINE
colobob
  • 8 Thanks
  • 4 posts
Posted October 18, 2017 - 08:16 PM
Guys, I'm planning on attending this year -- will be my first time at this plow day.  What are the recommended hotels in the area.  I'll be driving up from Knoxville.  Look forward to participating this year.
Bob
#43 olcowhand ONLINE
  • 42,301 Thanks
  • 31,772 posts
Posted October 19, 2017 - 08:43 AM
Bad news guys. Talked with Steve just now, and he's not going to have the soybeans harvested in time. That coupled with all my Dr's appointments and there's just no way I can handle it at a later date. I'm sorry everyone, but life is crazy busy.
  • Grumpy, limebuzz, Craig. and 5 others have said thanks
#44 SupplySergeant ONLINE
SupplySergeant
    Eggman's Dad
  • 1,919 Thanks
  • 1,062 posts
Posted October 19, 2017 - 09:16 AM
Sometimes you just gotta take care of yourself! Thanks for trying, Daniel. Now looking forward to spring!
  • olcowhand, limebuzz and dropped82 have said thanks
#45 KennyP ONLINE
  • 40,036 Thanks
  • 46,727 posts
Posted October 19, 2017 - 09:41 AM
Saddened to hear this, but life has a way of doing things we don't agree with. Maybe I can make the Spring session. Thinking about a 2 bottom for Alice!
  • olcowhand, limebuzz, dropped82 and 2 others have said thanks
