1872 hydrostat seal replacement
3 replies to this topic
#1 veizter OFFLINE
veizter
  • 15 Thanks
  • 22 posts
Posted September 17, 2017 - 12:01 PM
the seal needs replaced on the hydrostat . part #5  . I have most of it apart , but how does the shaft come out to get at the seal ? I'm trying to do this in the tractor, but I don't know if the shaft bracket comes off ? does the whole shaft pull out and then replace the seal and slide the shaft back in ?
#2 diesel nut ONLINE
diesel nut
  • 685 Thanks
  • 421 posts
Posted September 17, 2017 - 02:08 PM
If its the one behind #45 the hydro has to come out and apart to get at it.  In the parts break down #45 goes inside and is pinned to #42 by #41  Here's the link to the trouble shooting guide for the CC 682 & 782 http://gardentractor...ouble-shooting/.  The pumps have a few different part numbers than yours but removal and dissasembly instructions are the same.  I'd try to explain it to you as I've done probably close to a dozen but with a pounding head cold right now I'm afraid I'd mess up or miss a step, but the guide in the link is the same as the one I use at work.  Hope this helps.                                  Stewart
  • veizter said thank you
#3 veizter OFFLINE
veizter
  • 15 Thanks
  • 22 posts
Posted September 17, 2017 - 09:24 PM
as I pull the pump apart , are the internal pump parts going to stay together or will it come out in pieces ? . I've been a maintence man my whole life , I just don't want to mess this up .I don't need to rebuild the pump , just need to replace the seal . I have the transaxle out , laying on the floor , will take the pump off tomorrow or Tuesday .
#4 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted September 17, 2017 - 09:47 PM
Download the service manual, disassembly of the pump is covered in it. Make sure you read it a few times before you start taking it apart.
