I need to replace my 1811 rear axle bearing
6 replies to this topic
#1 Loon64 ONLINE
Loon64
  • 110 Thanks
  • 74 posts
Posted September 16, 2017 - 04:38 PM
I was moving dirt with my 1811 today and the rear end started to squeak, so I took off the rear wheels
and the right side is binding up. So I think either the wheel bearing or a bent axle.
 Any thoughts?
                                                           Dave
  • Mark 149 J. said thank you
#2 propane1 ONLINE
propane1
  • 9,483 Thanks
  • 4,411 posts
Posted September 16, 2017 - 06:29 PM
Bearing I would say.
Noel
  • Loon64 said thank you
#3 olds45512 OFFLINE
olds45512
  • 1,415 Thanks
  • 702 posts
Posted September 16, 2017 - 06:32 PM
You sure it's not the brake hanging up?
  • Loon64 and Mark 149 J. have said thanks
#4 diesel nut ONLINE
diesel nut
  • 767 Thanks
  • 460 posts
Posted September 16, 2017 - 09:07 PM
:yeah_that:  It's possible that you got dirt piled up on the top of the brake caliper especially if you have chains on the tires and some if it might have worked down in between the pads and disc.  Two bolts and you can pull the whole brake assembly off and check.  If it's the outer bearing, with the brakes off it you should be able to wiggle the axle around to see if there's any play.
  • KennyP, Loon64 and Mark 149 J. have said thanks
#5 Loon64 ONLINE
Loon64
  • 110 Thanks
  • 74 posts
Posted September 18, 2017 - 08:34 AM
I have taken off the brake caliper and it is not that. when I turn the hub it gets bound up.
Maybe a bent axle?
Edited by Loon64, September 18, 2017 - 08:36 AM.
#6 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 2,847 Thanks
  • 1,587 posts
Posted September 18, 2017 - 10:26 AM
Sounds like taking out the axles is next.  It will be interesting to see what's causing the problem.  Hopefully it's something minor.
#7 olds45512 OFFLINE
olds45512
  • 1,415 Thanks
  • 702 posts
Posted September 18, 2017 - 03:17 PM
If it turns out you need an axle send me a pm.
