Fixed my Trailer ramps Today!
6 replies to this topic
#1 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted September 14, 2017 - 02:17 PM
Some time back, I had to haul my daughters Blazer home so we could put a fuel pump in it. I got it loaded fine, but we bent my cheapy ramps badly when unloading. So today, I went about beefing both sets up a bit. These are HF 6' ramps. Rated at 1000 lbs. Allis weighs in at close to 1500. Thought I had better do something now.
The set I just bought (and were still straight), I bolted in a section of composite deck board. That should help them out.
The bent up ones, I ripped some 2X boards to fit and bolted them in. I trimmed all protruding threads back to the nuts.
Should make these last a bit longer!
  • olcowhand, Gtractor, grnspot110 and 8 others have said thanks
#2 jms180 OFFLINE
jms180
  • 1,461 Thanks
  • 1,536 posts
Posted September 14, 2017 - 04:31 PM
Them rascal will not bend now
Edited by jms180, September 14, 2017 - 04:32 PM.
#3 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted September 14, 2017 - 05:23 PM
I've had, broke first use. Throw them away, just use the boards and maybe run a 2 x 4 on edge underneath for strength. OR......I have nice folding aluminum ones, which also come one-peice now and they work much better for GT's and can do the big ones and golf cart and such. Won't hold a car, I have other trailer for that use if needed.
I once had a flatbed truck and needed real big long ramps for tractors and cars. I took frame rails from a 2 ton truck, wood over them, two 2x4's or maybe 6's? and bolted to sides. The frame had a bend in it, so made that just like boughten ones with an arc. I used them for sides on the flatbed when not used as ramps. They were real ball-breakers tho to lift up out of slots and slide to back of truck and hook up. Darn things were about 12" long!  Over-kill!
#4 olcowhand ONLINE
  • 40,329 Thanks
  • 31,166 posts
Posted September 14, 2017 - 06:46 PM
That oughta do it Kenny!   :thumbs:
#5 FixItCharlie OFFLINE
FixItCharlie
  • 518 Thanks
  • 335 posts
Posted September 16, 2017 - 10:23 AM
I like your idea for added support. I have the same type of ramp that I found at another store on close out. I was not comfortable with the width so got another set to make them double wide.
Charlie
#6 KennyP ONLINE
  • 37,391 Thanks
  • 45,446 posts
Posted September 16, 2017 - 11:01 AM
I have 2 sets now, so can do the same. These are rated at 1000 lbs a pair and Alice weighs close to 1500.
#7 ShotgunWedding ONLINE
ShotgunWedding
    Garlic Jedi
  • 519 Thanks
  • 247 posts
Posted September 18, 2017 - 11:18 AM
That's doing it up right!!!
