Need some hydraulic lift help
35 replies to this topic
#1 SgtMoonracer OFFLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted September 14, 2017 - 03:29 AM
So I gambled on a hydraulic lift on eBay, and won it. It's a 18703-04, and I'll be putting it on my 900. The seller said that the lift was working when removed from a tractor that had a blown engine. The rest of the tractor was scrapped.
Unfortunately, some of the important pieces of lift were not saved. I have the reservoir and it's mounting bracket, the two pump supports, and the hydraulic lift cylinder.
I'm missing the mounting bracket for the cylinder, (part #1714790) the belt guard, (1714774) and the entire control rod assembly (1714791).
Can someone measure the mounting bracket for the cylinder and give me an idea what I need to look for to fab something up? An idea of the thickness of the bracket would also help. It looks like it's just an "L" shape with the large flat portion bolting onto four existing bolts on top of the transmission, but I need a rough idea of the size of the other angle the cylinder bolts to. I could also use some measurements of the control rod and the bends in it.
Alternatively, if anyone has any of those pieces lying around from a parts tractor, I'd be happy to take them off you hands for a fair price!
Thanks in advance!
Edited by SgtMoonracer, September 14, 2017 - 03:43 AM.
  • logmillingman said thank you
#2 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted September 14, 2017 - 10:44 AM
Hi, I have a lift on my 900. I will try and get out there in the barn and get some pictures/measurements for you. The lift does work great when all restored. The belt guard is nice but will function without it. The control rod could be bent out of 3/8" template rod, the mounting bracket basically flat steel with a welded on lip or could have it bent at a shop could probably make one easy enough.
  • blackjackjakexxix, Newpaws493, logmillingman and 2 others have said thanks
#3 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,833 Thanks
  • 990 posts
Posted September 14, 2017 - 08:38 PM
Have a NOS pump complete uninstalled , thought it'd be easier.
It's not square Pic 1
That measurement is 9"
Pic 2
Measures 4-3/4" narrow end
Pic 3
Measures 5-1/4" wide end
Pic 4
Measures 1-5/8"
Pic 5
9/16" diameter
Pic 6
9/16" diameter hole depicted in Pic 5
Pic 7
Holes are 11/32" in diameter. Measurements
Edited by WrenchinOnIt, September 14, 2017 - 08:51 PM.
  • Bruce Dorsi, blackjackjakexxix, Newpaws493 and 3 others have said thanks
#4 SgtMoonracer OFFLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted September 14, 2017 - 09:13 PM
Thanks so much. Now if someone can give me an idea of the bends on the control rod, I'll be in business.
  • WrenchinOnIt and logmillingman have said thanks
#5 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,833 Thanks
  • 990 posts
Posted September 14, 2017 - 09:41 PM
It's a rolling bend, center lines of bends are not inline
Pic 1
Pic 2
1-3/4"
Pic 3
3/8" rod. The Metal pivot block looks similar to a standard Bolens issue, perhaps Rick Show or Brian Bolens Parts and Supplies can help
If your interested in having me replicate them shoot me a PM and we'll go from there.
Edited by WrenchinOnIt, September 14, 2017 - 09:56 PM.
  • Bolens 1000, Husky, Bruce Dorsi and 6 others have said thanks
#6 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted September 15, 2017 - 06:26 AM
Hi WrenchinOnit you beat me to it. Nice job on the pics and measurements thank you for helping out so quick.
  • WrenchinOnIt, logmillingman and SgtMoonracer have said thanks
#7 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,833 Thanks
  • 990 posts
Posted September 15, 2017 - 09:44 AM
Hey Ed
Well I thought I'd horn in and help because it's still in the box and easy to get to, know you would of disassembled yours for the measurements and I was hoping to help you both, by doing so I knew I was leapfrogging your intentions,but figured I was saving you some work. Happy to be of assistance.
  • Husky, logmillingman and SgtMoonracer have said thanks
#8 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted September 15, 2017 - 11:21 AM
Hey Ed
You saved me some time. Having it off the tractor sure makes measurements more accurate. I did not realize the base was tapered either. That NOS pump must be really nice. I had to put a few orings into mine but that's about all. It works really well on the 900 and looks fantastic with Stew's hand sewn seat on there.
#9 SgtMoonracer OFFLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted September 15, 2017 - 01:35 PM
I certainly appreciate the help. Mine isn't going to look nearly as nice as yours, but I'm going for function over fashion. I'm crossing my fingers and hoping that the lift works when I get it installed. All indications are that it will.
I just wish the guy I bought it from would have taken a couple minutes to unbolt the brackets.
  • Husky, WrenchinOnIt and logmillingman have said thanks
#10 Husky OFFLINE
Husky
  • 1,341 Thanks
  • 1,151 posts
Posted September 15, 2017 - 02:20 PM
Yah, that's too bad he did not give you everything... It should work well for you. If you need any documentation I have parts and user guides for it. My 900 was purchased from someone who did a very thorough restoration on it. That's why decided to put the lift and the custom seat on it. I rake my 250' driveway with it and it does well even has down pressure, pretty cool. Let us know if you need anything else.
#11 SgtMoonracer OFFLINE
SgtMoonracer
  • 61 Thanks
  • 58 posts
Posted September 15, 2017 - 07:59 PM
WrenchinOnIt is going to assist me in fabbing up the needed parts. I don't have access to equipment to make the job easy. I really appreciate the information and assistance.
My 900 is a conglomeration of 900 tin, a TR10D engine from a tractor unknown, and the rear end from a donor 1050 after I kind of ruined the original. I've had it for two years now, and bought it mainly to move snow. Thankfully, SW PA has been relatively snow free the last two years, but it's only a matter of time...
#12 logmillingman ONLINE
logmillingman
  • 991 Thanks
  • 462 posts
Posted September 15, 2017 - 09:31 PM
any one know whats the going price for a complete hydraulic lift kit is?
#13 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3,066 Thanks
  • 2,144 posts
Posted September 16, 2017 - 07:44 AM
Ones with all the correct pieces including the belt guard are doing $225.00-$300.00
  • WrenchinOnIt, logmillingman, SgtMoonracer and 1 other said thanks
#14 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,833 Thanks
  • 990 posts
Posted September 19, 2017 - 04:49 PM
Here ya go Sarge (I think) plasma cut out the bracket. Heat and bender on the rod. They are like horse shoes ,hand grenades and bombs, I got close. Pretty sure they will work. Some holes to drill in rod ,may scare up a handle grip. You'll need that small angle bracket as well it's next but... I've followed up this left you hanging in suspense with a PM :)
Edited by WrenchinOnIt, September 19, 2017 - 04:59 PM.
  • wilberj, blackjackjakexxix, Newpaws493 and 2 others have said thanks
#15 wilberj ONLINE
wilberj
  • 5,128 Thanks
  • 5,636 posts
Posted September 19, 2017 - 07:10 PM
Last 3 that sold on ebay were under $200 and I got two of them.
  • Husky said thank you
