Throttle Question
4 replies to this topic
#1 Papajoe OFFLINE
Papajoe
  • 2 Thanks
  • 19 posts
Posted September 12, 2017 - 01:49 PM
On my Sunstar the throttle goes all the way to hi but works itself back down and I have hold it in place. Is there an adjustment I can make, or something I can do to stop this? Thank you in advance.
#2 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 10,454 Thanks
  • 5,764 posts
Posted September 12, 2017 - 02:30 PM
Is the throttle lever sliding back to 'slow' position as things vibrate?  If so, put a slight bend in the exposed area when the setting is on slow (Machine off) and it will bind in the casing..
OR:
Look up the (B&S?) engine service manual for more on it.  Post up the Model # and code # and maybe someone will be able to cite facts from memory..
  • Papajoe said thank you
#3 Papajoe OFFLINE
Papajoe
  • 2 Thanks
  • 19 posts
Posted September 12, 2017 - 05:22 PM
Well it moves back down but quite to the position.
#4 chieffan OFFLINE
  • 10,123 Thanks
  • 6,626 posts
Posted September 12, 2017 - 08:02 PM
Look where the throttle lever rotates on the mounting bracket.  Some have a lock nut to adjust the tension.  If that's the case with yours, snug that nut up a bit.  If it is riveted, have to remove the throttle bracket from the tractor.  Lay the head of the rivet on a hard solid surface and using a ball pien hammer, strike the mushroomed end of the rivet till the throttle feels like it will stay where you put it.   Might have to do this a couple times to get it right but don't go to far or it will be real hard to move.  Good luck. I have had to do this with several of mine.
Edited by chieffan, September 12, 2017 - 08:04 PM.
#5 Papajoe OFFLINE
Papajoe
  • 2 Thanks
  • 19 posts
Posted September 13, 2017 - 07:54 AM
Great thank you. I will check this tonight.
