Rear PTO
4 replies to this topic
#1 jmorg OFFLINE
jmorg
  • 3 posts
Posted September 12, 2017 - 06:22 AM
The rear PTO on my GT20 spins freely and does not engage. The front and center work as they should. I am relatively new to this tractor thing so any suggestions would be appreciated. Thanks
#2 KennyP ONLINE
  • 38,231 Thanks
  • 45,866 posts
Posted September 12, 2017 - 06:26 AM
Maybe a wiring issue? Or is this not electric?
#3 boyscout862 ONLINE
  • 12,831 Thanks
  • 9,158 posts
Posted September 12, 2017 - 06:41 AM
Have you read the manuals? If you need copies, just download them from our Manuals Section. Good Luck, Rick
#4 shorty ONLINE
shorty
  • 5,465 Thanks
  • 5,257 posts
Posted September 12, 2017 - 08:41 AM
I would try the easy trouble shooting first. Check voltage at the switch then the clutch.
#5 djordje33 OFFLINE
djordje33
  • 21 Thanks
  • 53 posts
Posted September 12, 2017 - 08:44 AM
You need power to the field, in order to engage the rear pto. If the one wire isn't "hot" with the switch on and the tractor running, switch or field could be cooked. If someone had this apart and air gap exceeds .045" between clutch and rotating field, might not be locking up under power.
If 12v is getting to coil, check resistance on coil.
Could be a severed wire or something else trivial.
The wiring on these things is crazy, with the interlock scheme. I've seen so many "shoemaker" jobs with bypass wiring, cause more problems than what was intended to fix. I came up with a logic to wire everything clean and simple, starting from scratch, making things a breeze to diagnose. Hopefully, yours is semi-intact.
