Tecumseh Loud backfire
ss ignition rebuild repower trash rebuild kit used engine tec oh 140 help
18 replies to this topic
#16 TAHOE OFFLINE
TAHOE
  • 8,337 Thanks
  • 5,819 posts
Posted September 21, 2017 - 11:06 AM
If needed I do sell the Tecumseh spring compressor tool for the valves
http://bolenspartsan...sears-suburban/
i didn't know those existed when I redid mine so I built my own out of angle.
  • Bolens 1000, olcowhand, logmillingman and 1 other said thanks
#17 1400 medfra OFFLINE
1400 medfra
  • 18 Thanks
  • 21 posts
Posted October 09, 2017 - 09:40 AM
I can supply you with the head gasket and upper cylinder o-ring kit both instock
http://bolenspartsan...uburban-34225a/
http://bolenspartsan...uburban-35075a/
Valves and seats are NLA, you can resurface the valves and seats if there is not much damage, only other way I can offer new seats is with a new cylinder head.
Hi Brian,
 Parts arrived at the speed of light, Thanks for the prompt service!
  I have the head off and it is at the machine shop.
  I have a couple question about the valve cover O ring kit.
 #1 Do you know what the two small screws are for, or where they go?
 #2 The kit came with two medium size O rings, one is black and pliable, the other one is white, quite hard and rather rigid  that I assume go under the lower valve spring retainer but which valve gets what color?
  Can you shed any light on this or direct me to someone that can help?
#18 Bolens 1000 ONLINE
  • 15,555 Thanks
  • 18,319 posts
Posted October 09, 2017 - 10:33 AM
Hi Brian,
-The small screws are for the top breather plate the breather tube sticks into to.
-The white o-ring is for the exhaust side, the Black one is for the intake
Those two size o-rings in question are #'s 25 & 25A in this diagram
  • 1400 medfra said thank you
#19 1400 medfra OFFLINE
1400 medfra
  • 18 Thanks
  • 21 posts
Posted October 09, 2017 - 11:01 AM
THANKS A MILLION!
  • Bolens 1000 said thank you
Also tagged with one or more of these keywords: ss ignition, rebuild, repower, trash, rebuild kit, used engine, tec oh 140, help
