Craftsman 50 inch deck (info needed)
61 replies to this topic
#46 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted November 14, 2017 - 07:50 PM
Finally! Someone suggested a tool that I have (a miter box with a saw) I forgot I had this :wallbanging: . and wasn't putting 2+2 together. It was hanging behind the TV in plain site all this time. Oh, and here is the finished skid, just need to make the one for the other side now.
#47 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted January 27, 2018 - 08:04 PM
So, I am picking up where I left off on the Craftsman 50” deck. I tackled the front anti scalp roller. Probably way more elaborate than it needed to be. The new one was a 12” Boat deck roller that I cut in half with a jig-saw (had it out for another honey-do project). I picked up an 80c nail to make a straighter bar, and some brass bushings for the ends. Still had some slop, so I used a piece of red tubing from a HF fluid pump and a piece of unknown white tube to keep the brass bushings in place. All mounted and looks like it will work fine. Next is to work on the idler bracket (as I won’t have a top cover) and make a LH runner, this should be easier than the RH one.
#48 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted January 28, 2018 - 06:55 PM
I ordered the last part (that is available) for the 50” deck, the grass shield. The top cover is NLA so I fabricated a bracket for the idler support, and while at it I made the other runner. Waiting on the paint to dry on the rear anti-scalp pins so I can get those installed. Next weekend I’ll fit this on Hulk II and power it up. Should be a big difference going from 44” to 50”.
#49 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted February 02, 2018 - 09:59 PM
Finished the deck tonight. I had to fab a support bar, drill some holes and presto, the shield in installed. All that is left to do is get this mounted on Hulk II or BOH (Haven't decided yet) to check the drive belt and spin it up. Grandson is here, didn't have much for him to do so while watching the Odd Squad Movie I gave him a defunct pocket game and a screwdriver to dissemble / destroy. I figure it helps for dexterity using small tools, plus kept him busy while watching TV.
Going to a Teenage Mutant Ninja Turtles exhibit as a Science museum tomorrow.
#50 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted February 03, 2018 - 08:48 PM
Had a good day at the Mayborn Museum. Lots of hands on stuff to do there. Got the deck mounted, fit like a glove, should be able to test it tomorrow. https://www.baylor.edu/mayborn/
#51 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted February 03, 2018 - 10:23 PM
Well I think I spoke too soon. Not sure how I am going to correct this. The R side gauge wheel bolt is catching on the Terra Track tread when the deck is raised. The L side clears fine. I don't see any way to shift the deck to the right a nudge, or move the gauge wheel out some. Oh BTW the extra 6" are on the Chute side as compared to RED's 44" deck.
#52 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted February 03, 2018 - 11:24 PM
Carriage bolt head has a lower profile.
#53 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted February 04, 2018 - 12:32 AM
I looked at this again, (noticed it in the pictures) not sure if it is designed this way but the Left bar has a slight bend inward. I'll try swapping the LH and RH wheel bars tomorrow and see if that fixes it.
  • KennyP and shorty have said thanks
#54 4tom OFFLINE
4tom
  • 164 Thanks
  • 178 posts
Posted February 04, 2018 - 10:05 AM
Weld a bolt to the gauge wheel bracket and grind it flush on the tire side?
#55 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted February 04, 2018 - 01:07 PM
Swapping the wheel mounts didn't work, the bar looked bent but wasn't. I noticed I had a lot of clearance with the deck lowered, so I adjusted the wheels down. I have about 1/4" clearance with the deck lowered, and about the same from the rear tire with the deck raised. Good to go now. I checked to see if any belt guards like I have on RED was still available. (106214X) comes up as NLA.
Here is the turn-up
#56 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted March 16, 2018 - 06:25 PM
Decided to try out BOH and the free 50” deck today “Thanks Brandon”! I used RED to get under and around the trees. RED has the 6 speed peerless, and 5th and 6th works a treat for my flat level yard. BOH has the 3 speed Hi-Lo setup, and for me, 2H seems too slow, and 3H seems too fast (I also tried 3L which is slower than 2H). I mowed in 3H and although it cut OK, it isn’t great. The cut is level, but was leaving stragglers (May just be winter toughened grass). The grass is dry, and dusty. I almost felt bad getting BOH that dusty. After cleaning BOH back up, I was wondering if the blade speed was too slow, as BOH normally has a 44” deck. I checked the blade speed between RED and BOH. Both are at 3600 RPM so that’s not it. I may have too much front to rear tilt, Front lip at 1-1/4” and rear lip at 3”, I’ll need to check the manual on this.  RED will still be the main mower for now, BOH will be the back-up. Now it is time to work on the back yard.
https://www.youtube....eature=youtu.be
  • olcowhand and bbuckler have said thanks
#57 olcowhand OFFLINE
  • 42,900 Thanks
  • 31,942 posts
Posted March 16, 2018 - 07:30 PM
I think the blade tip to ground up front is supposed to only be 1/4" lower than rear.  Someone please correct me if I'm wrong.
#58 shorty ONLINE
shorty
  • 5,839 Thanks
  • 5,421 posts
Posted March 16, 2018 - 08:35 PM
I think the blade tip to ground is supposed to only be 1/4" lower than rear. Someone please correct me if I'm wrong.
That is what I have understood and try for.
#59 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted March 16, 2018 - 09:00 PM
Yea, it has a definite tilt. I'll see about leveling it out to a 1/4 to 1/2 tilt and try it again. Not much I can do to find a gear between 2H and 3H. Throttling down is not an option. But if I can get the deck to cut decent in 3H, then I may have a winner.
  • olcowhand and KennyP have said thanks
#60 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,494 Thanks
  • 4,588 posts
Posted March 17, 2018 - 04:40 PM
Leveled the deck to where the back is 1/4" higher than the front. Need the grass to grow to see if this helped.
