Snowblower for 1655/1855/1650/1850 or alternative
8 replies to this topic
#1 Coachw34 OFFLINE
Coachw34
  • 10 posts
Posted June 24, 2011 - 04:42 PM
I am looking for a snowblower for this tractor. However I am seeing it is difficult to find one. Is there an alternative company (ariens, simplicity, etc) that made a snowblower that might attach with little modifications?
Thanks,
Mike (new to forum)
#2 Stoneman OFFLINE
Stoneman
    Masseyholic
  • 26 Thanks
  • 157 posts
Posted June 24, 2011 - 07:27 PM
What tractor do you exactly have? the 50 series use a belt driven blower (42'') and the 55's used a shaft driven blower (48''). I think sears/craftman used the same blowers, but i do know that they do not bolt right up. Where are you locatated? Someone might be able to help you out near by...... possibly me.
and last....... :welcome: to GTtalk
Edited by Stoneman, June 24, 2011 - 07:33 PM.
#3 Coachw34 OFFLINE
Coachw34
  • 10 posts
Posted June 24, 2011 - 08:03 PM
I have a 1655 with the shaft drive. I am sorry. I thought the 50 series snapper was the same tractor. That is a big difference. O)
#4 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted June 24, 2011 - 08:11 PM
When I bought my MF 1655 it came with a Ariens snowblower 48" dual stage.The previous owner had made mounts out of 3" x1/4 flat bar.I didn't think it worked to well so I made a differnt mount out of 1x1 sq tubing and made it quick attach to the tractor.I don't have the Ariens attached to the 1655 as I've made it to fit onto a different tractor.Last fall I made a 38" snapper dual stage blower into a 48" wide blower and made it fit onto the MF 1655.I don't know how to post the link to it . Its posted in the Mechanical Forum under Snapper 38" blower made into 48" Do a search and its there.Larry
Edited by massey driver, June 24, 2011 - 08:17 PM.
#5 Coachw34 OFFLINE
Coachw34
  • 10 posts
Posted June 24, 2011 - 08:21 PM
Thanks. I just read your work and that was incredible. I don't think I could do that. I am hoping if can find an original snowblower or a snowblower by another make that has a shaft drive. I think I have the ability to create a mount as long as I can connect the pto. I saw a gravely snowblower that was shaft drive. Once I have makes of blowers I can start my search for them along with my search for an original blower.
mike
Edited by Coachw34, June 24, 2011 - 08:36 PM.
#6 ErnRemy OFFLINE
ErnRemy
  • 21 Thanks
  • 153 posts
Posted July 03, 2011 - 11:07 PM
I will be mounting 46 inch haban (sears) snow blower on my 1655 later this year. This snow blower is belt driven off of a vertical shaft engine. the thing with this blower it there is a 90 degree gear box at the back of the blower where it attaches to the frame under your feet. This gear box drives a shaft that travels forward to the front of the snow blower to drive the fan and auger. I will be removing the gear box and building a shaft on pillow blocks that will run pulleys (sprockets) down to the shaft under the snow blower . This upper shaft will be driven by the same pto shaft that drives the belly mount mower.sears_craftsman_842.242560 Front Lift Assembly.jpg The gearbox pulley and idler pulley will be gone and that is where I will mount the driven shaft from the front PTO. Not sure if I will drive the lower shaft with chain or pulley.
the pulley will be quieter but the chain will be positive in the snow conditions here is a web page with a little better picture as to how the shaft is driven underneath the blower frame
http://www.searspart...Mod=&SID=CJxPDx
#7 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted July 04, 2011 - 08:41 AM
Just to save you some extra work possibly?? Check the rotation of everything to make sure it'll all be turning in the right direction.When I took the blower from my MF 1655 and mounted it to my MF gc 2300 I mounted it all up to fit and the first time I turned it on the blower was running backwards.The front pto on one rotated cw and ccw on the other so lesson learned.Larry
#8 ErnRemy OFFLINE
ErnRemy
  • 21 Thanks
  • 153 posts
Posted July 04, 2011 - 06:44 PM
here are some pictures of the real snow blower and yes the rotation is correct I am hoping this thing throws snow to no end. As you can see the gear box that will be removed and a shaft on pillow blocks will sit where the driven pulley is now with pulleys ( sprockets) driving down to the lower shaft. This blower is very well built should last a long time:smile1:IMG_0919.jpg
#9 massey driver OFFLINE
massey driver
  • 1549 Thanks
  • 1613 posts
Posted July 04, 2011 - 07:16 PM
That sure looks like it'll work.After seeing the pics I can sure see what your intending on doing.It looks like a good unit and should blow snow.Thanks for the pics.Larry
