Looking for info on my walk behind
david bradley 91757597
8 replies to this topic
#1 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 03, 2017 - 01:02 PM
Hi,
I'm looking for info on a David Bradley that I received from my grandmother that belonged to her father.
The model number is 91757597.
From what I've researched this is a Super 3 model and should have a hood;however this one is missing.
I was told the Tecumseh on it is 6HP and was changed from the original by my great grandad, but I read that later models came with a Tecumseh.
I believe he had several implements but the only one I have is a bush hog that is attached to the front. I've seen pictures of other types of rotary mowers online but have not run across any like mine.
I got the engine running however the throttle linkage is missing. It was enough to get it moving and it has forward and reverse.
I neglected to take pictures but will upload a few as soon as I get a chance.
Any info would be greatly appreciated.
#2 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 04, 2017 - 11:35 AM
Pictures as promised. I've looked in the manuals section and don't see one for my model. If anyone knows where I can find any literature on this thing I'd appreciate it. A lot of the links I come across are broken.
#3 jimmy G OFFLINE
jimmy G
  • 1481 Thanks
  • 973 posts
Posted September 04, 2017 - 12:24 PM
I might have a couple tec's like yours if you need pics of the linkage, model and ser. No's are stamped on the fan shroud, h 60 would indicate if it is a 6hp(h 50 indicates 5hp, ect.)
  • skatetheame said thank you
#4 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 04, 2017 - 01:20 PM
Thanks, a pic of the linkage would help out a lot. I rigged one for now but I don't think its quite right. I can't find anything stamped in the shroud. There are two stickers still intact: the the logo and instructions, neither of which give any specs
#5 Alc ONLINE
  • 9079 Thanks
  • 8321 posts
Posted September 05, 2017 - 05:45 AM
Welcome to GTTalk . I think this is the manual for the weed cutter
#6 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 05, 2017 - 07:13 AM
Thanks, that looks like it and explains a lot.
#7 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 05, 2017 - 07:40 AM
Ok, on further inspection I've found the model and serial number on the engine. It is in fact on the fan shroud.
Mod: HS50-67124E
Ser: 5137B
So it appears to be a 5 horse.
#8 jimmy G OFFLINE
jimmy G
  • 1481 Thanks
  • 973 posts
Posted September 05, 2017 - 09:15 AM
Throttle cable pulls on the spring,spring pulls on the governor throw arm,arm pushes throttle,the farther up the throw arm the spring is hooked the more leverage it has,throttle response is controlled by moving the linkage in or out on the throttle plate
Edited by jimmy G, September 05, 2017 - 09:44 AM.
#9 skatetheame OFFLINE
skatetheame
  • 1 Thanks
  • 6 posts
Posted September 05, 2017 - 11:28 AM
Thanks, that's how I had it but I think my linkage was too long. When I replace the pull cord I'll test out my shorter linkage.
