Front eletric clutch center bolt torque spec on a kt17
6 replies to this topic
#1 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted September 02, 2017 - 09:24 PM
Hi does anyone know the torque spec for the front pto center bolt  item 11 circled in red
#2 Piddler2 OFFLINE
Piddler2
  • 5 Thanks
  • 14 posts
Posted September 02, 2017 - 09:32 PM
I recently snuggled mine up till lock washer flattened but I had clearence issues and had to install a .030 shim to get proper air gap on clutch.
#3 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,164 posts
Posted September 02, 2017 - 09:38 PM
I don't have a clue. I don't have manuals with that kind of info. Could it be traced through a manufacturer? Or a service manual? All I got are parts manuals.
#4 chieffan ONLINE
  • 9,574 Thanks
  • 6,412 posts
Posted September 03, 2017 - 07:14 AM
Standard torque specs for the size of bolt should work.   I usually put a dot of lock tight on the threads and turn it in good and tight with a 8" ratchet, not a breaker bar.
#5 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted September 03, 2017 - 01:34 PM
ok thanks all Now I do not have the tractor in front me at buddys  house. When I tighten that nut on sat did not check to see if the bearings inside pulley to see if this nut preloads the bearings? That's why I was wondering about torqueing that bolt.
Edited by 71mustangman, September 03, 2017 - 01:36 PM.
#6 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted September 04, 2017 - 05:37 AM
Hi there this is the first time I am adjusting an electric clutch. where did you install shim?
#7 71mustangman OFFLINE
71mustangman
  • 54 Thanks
  • 89 posts
Posted September 06, 2017 - 09:54 PM
Well everything is good to go I torqued that bolt just enough to collapse the spring lock washer. I also put a few drops of lock tight on bolt prior to install. Thanks again mustang man If some gets a chance I Shure would like to know where to shim the clutch?
Edited by 71mustangman, September 06, 2017 - 09:55 PM.
