Reading threads & posts
4 replies to this topic
#1 Alc OFFLINE
  • 7,256 Thanks
  • 7,595 posts
Posted June 24, 2011 - 09:30 AM
I read almost all the posts on the site , I really enjoy the troubleshooting ones . Even though I may never own a Case, Bolens ,WH ect. some of the basic troubleshooting is the same . It also keeps things fresh in your mind . Just the other night the JD318 battery light came on . It's been awhile since I worked on a charging problem on a small engine .I remembered reading a thread on checking a voltage regulator , knew to check the a/c wires , had 31 vac , only 12.3 on the center dc terminal , no voltage drop from regulator case to ground , dug out a old regulator that I saved ( I save everything !!) and was back cutting grass in less then 1/2 hour . I've learned some pretty cool hydraulic testing and plumbing , rust removal , the way some things can be repaired without replacing them . Attachments people have , make or modified . The progress on the builds are fun to follow up too. Watching something rise up from the scrap yard to a like new condition is great !!! Thanks to all GTtalk members , Al
  • 14,889 Thanks
  • 15,514 posts
Posted June 24, 2011 - 10:14 AM
I love reading the old post also Al, I learn stuff every day from this site. It's great to have these resources to use.
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted June 24, 2011 - 11:37 AM
I usually read anything that I think I want to read, even JD stuff, because you never know when a problem's solution, a project idea, or even a good tire selection will have crossover applications for other brands.
#4 Alc OFFLINE
  • 7,256 Thanks
  • 7,595 posts
Posted June 24, 2011 - 01:41 PM
Forgot to mention all the tips I picked up on gardening too.
#5 KennyP ONLINE
  • 40,984 Thanks
  • 47,148 posts
Posted June 26, 2011 - 06:54 AM
I snoop around around in most all the threads. You can learn a lot and yes, a lot does apply to different makes. I have learned a lot of things doing this. I notice a lot of answers to questions are from someone who has a different make. Glad we have members who share their knowledge. To me, that makes this a very special forum. I don't know as much as others, but once in a while I make a comment about something that helps. And I am very happy to do that, plus I am learning by reading. Great bunch of members here that I can thank every day for their help and concerns for others.
