Increasing the speed of the snow blower
30 replies to this topic
#16 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 05, 2017 - 09:48 PM
More than anything, I am worrying about trashing the main drive belt from the pto to the front angle gear pulley in short order. Time will tell! :)
I did have to go from one belt to two on the PTO. One belt in heavy or hard packed snow couldn't take the load and would break. If it was wet the one belt would slip and the chute would load up. With two it has been no problem at all.
  • propane1, John Arsenault and dualresponse1731 have said thanks
#17 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted November 06, 2017 - 06:58 PM
not to hijack the original thread, but how did you make double pulleys? My PTO has two different sized pulleys on the engine. How did you do it?
#18 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 06, 2017 - 11:37 PM
That's a good question! I'll have to look at it and take a couple pictures I guess. Old memory ain't what it used to be.  :(
  • John Arsenault and dualresponse1731 have said thanks
#19 John Arsenault ONLINE
John Arsenault
  • 2,570 Thanks
  • 1,212 posts
Posted November 07, 2017 - 06:59 AM
If it sparks and idea, creates a conversation by all mean have at it....
Tractor talk is what we are hear for.
  • dualresponse1731 said thank you
#20 John Arsenault ONLINE
John Arsenault
  • 2,570 Thanks
  • 1,212 posts
Posted November 07, 2017 - 06:22 PM
Oh by the way when I made this post I was using the smaller blower. I have since then landed a deal on a haban blower and am now rethinking the whole idea of the pulley size increase. Its a bigger blower and from what I hear it even blows better so I am going to use my standard engine pulley until I feel the difference.
The wheel horse was the bigger of the two blower before.
#21 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 07, 2017 - 08:50 PM
Just read this and realized I didn't look at the blower today. Sorry! I'm putting a not e up right now so I look at it tomorrow.
#22 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted November 08, 2017 - 06:32 PM
Hey... get to it!!! I need solutions. It's getting colder here and could snow in the next couple of weeks!  :D  :D  :D
Edited by dualresponse1731, November 08, 2017 - 06:35 PM.
#23 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 08, 2017 - 08:34 PM
OK I have a photos for you. Had room for double sheave pulleys and machined a wide idler pulley. Don't recall if I had to do anything with the shafts or not.
Edited by Cvans, November 08, 2017 - 08:53 PM.
  • KennyP, Cat385B, propane1 and 2 others have said thanks
#24 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted November 08, 2017 - 08:43 PM
 If I can't explain it in a thousand words or less I'll take some photos
Betting on photos. Anybody wanna put $5 on it?
#25 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 08, 2017 - 09:08 PM
You Won  :D
#26 John Arsenault ONLINE
John Arsenault
  • 2,570 Thanks
  • 1,212 posts
Posted November 09, 2017 - 06:34 AM
Thats pretty tight, excellent job!
  • Cvans said thank you
#27 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted November 09, 2017 - 11:02 AM
Yes it is but well worth the effort. Hope you can come up with something similar.
Another thought, If you have room for larger diameter pulleys that will help. If there is room for just one you could go with a wider notched belt and that would help also.
Edited by Cvans, November 09, 2017 - 11:05 AM.
#28 dualresponse1731 OFFLINE
dualresponse1731
  • 255 Thanks
  • 175 posts
Posted November 09, 2017 - 12:27 PM
Thanks for posting that! My main drive pulley is a part of the electric clutch pto, So I am going to have to modify my pto to make it work. It's nice to know there are double pulleys available, as well as the tensioner roller.
#29 John Arsenault ONLINE
John Arsenault
  • 2,570 Thanks
  • 1,212 posts
Posted December 10, 2017 - 02:08 PM
Got to finally try out "Lucy" today, we did not get much snow but what we did get was that wet heavy stuff.  To test out the distance I did pack some nice wet heavy stuff in front of it with the plow tractor and let my wife shoot it off the bank.
I will say I am more then impressed with the modifications , this thing throw further then any single stage snow blower I have used and with the new engine you can barely tell your even running into anything. I have the rpms maxed at 3400 rpms just a smidgen higher then max output of engine just where the power curve starts to drop so when you hit the snow it falls right into the sweet spot of the power curve.
http://www.subarupow...power-curve.pdf
Engine specs.
https://www.facebook...28938670456515/
Video
We will give it another test when we get some real snow. But can tell already we are happy with the modifications.
  • DH1, KennyP and propane1 have said thanks
#30 Cvans ONLINE
  • 6,648 Thanks
  • 6,128 posts
Posted December 12, 2017 - 01:59 PM
Lookin good John! Be fun to see it after a good snow fall.
