not sure if anyone can help but i'm looking for some type of a ground cover plant ..would have to be ok in sun and shade..i'm done pushing a mower on a rather steep bank and need something that would grow fairly fast and take over all the grass etc on the bank , i'm in Pennsylvania so would have to tolerate the winter thanks for any help
ground cover
#1
OFFLINE
Posted September 01, 2017 - 06:13 AM
#2
ONLINE
Posted September 01, 2017 - 06:22 AM
How about some Bar Harbor Juniper, grows great on banks only gets about 6 inches high and is an evergreen. This stuff loves slopes.
- Alc, boyscout862 and Dcarr have said thanks
#3
ONLINE
Posted September 01, 2017 - 06:24 AM
https://www.uaex.edu...or-juniper.aspx
https://www.youtube....h?v=AcXHPjZ91_4
A link on top of what it looks like summer and winter , and the link below is a video of a guy explaining the plant.
- Alc and Dcarr have said thanks
#4
OFFLINE
Posted September 01, 2017 - 06:37 AM
I have a ground cover plant called "ajuga". It has green leaves that turn purple and a flower shoot about 6" that has little blue flowers. It definitely needs a border containment though, it can get invasive very quickly in lawns or areas you do not want. Grows pretty much anywhere in shade or sun.
- Alc, boyscout862, Bolens800uk and 1 other said thanks
#5
OFFLINE
#6
OFFLINE
Posted September 01, 2017 - 08:39 AM
Lots of roadsides use a plant called crown vetch. A plant I have that does well is pachasyndria also called Japanese spurge. Then there is blue rug juniper and honeysuckle. Hope this helps
#7
ONLINE
Posted September 01, 2017 - 09:30 AM
I would go with Crown Vetch and Rye Grass as a cover crop. Will take about a year for the Vetch to really fill in good. As with any seeding for small areas, put on about twice what is recommended to get it established quicker. Most of the farmer in the Midwest are planting Rye as a cover crop right after the main crop is harvested. Saves a lot of soil erosion from wind and water. Govt. pay them X amount per acre to plant it but nothing to kill it out next spring for the main crop.
#8
OFFLINE
Posted September 01, 2017 - 01:30 PM
Edited by jimmy G, September 01, 2017 - 10:59 PM.
- Alc said thank you
#9
OFFLINE
Posted September 01, 2017 - 09:20 PM
Being in PA you should be familiar with crown vetch. Stay away from it, as it is very invasive. It will show up every where on your property. My neighbor planted some on a bank on the property line some years ago & I have been fighting it ever since. It will not tolerate mowing however. PA DOT stopped using it years ago because it could not be controlled.
#10
OFFLINE
Posted September 02, 2017 - 08:06 PM
#11
OFFLINE
Posted September 05, 2017 - 08:25 AM
there is a scourge in the South called Kudzu that would fit your order but if you got it to establish in your cooler climate you'd say by to your shade, neighbors would be gunning for you and you'd probably sell your house in the end to get away from it lol, just thinking the envasefness of your cover choices
That stuff is of the devil, was brought over from somewhere in Asia, S. Korea, Vietnam, somewhere like that. truly an invasive species.
#12
OFFLINE
Posted October 17, 2019 - 02:00 PM
- Dcarr said thank you
