Shaw brake pedals
34 replies to this topic
#16 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted September 27, 2017 - 07:25 PM
Ted sent me a couple pics of his project to share. The first is the frame he built with the Powerking rear end and the second is the process of building the engine cover.
  • Alc and Clifford Bridgford have said thanks
#17 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted September 27, 2017 - 07:55 PM
Thanks Doug!...I tried to send 2 more, I think they're lost in space somewhere.I have the clutch and trans all done in the frame.Fabrication takes a lot of time! This will never be a real Shaw, but it should at least look like one....Ted.
#18 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted September 27, 2017 - 09:24 PM
Here are the pics of the trans in the frame.
Are you planning on direct connecting the engine or are you going to have a gear reduction with the chain sprocket?
#19 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted September 28, 2017 - 05:23 AM
Doug, I'm going to run a roller chain from the engine to a short jackshaft, and from that to the trans.I'm using the same size sprockets so it all runs at engine speed, but if I have to add more reduction I can change the transmission sprocket.I want to use the jackshaft to drive a small hyd. Pump and an alternator, I think I can tuck them in kind of out of sight around the flywheel area which will be covered up like on a real Shaw.Thanks for all the help!....Ted.
#20 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted September 28, 2017 - 06:22 AM
Actually, on the R12, the gen and hyd pump was mounted outside the frame and ran off the front pulley. BUT.....what you are doing should work.
#21 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted September 28, 2017 - 08:04 AM
I forgot to mention, this trans has a nice parking brake setup, so I decided to leave it on.Much better than having to do it with latches on the brake pedals.The only thing I'm worried about is the reverse ratio, these truck transmissions have a real low low and reverse.I hope it doesn't back up painfully slow.
#22 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted September 28, 2017 - 08:08 AM
I may hsve to put the alternator up on the frame as you said, I think I can at least get the pump hidden away though.I'll have to cross that bridge when I get to it.Thank you!
#23 Clifford Bridgford OFFLINE
Clifford Bridgford
  • 423 Thanks
  • 136 posts
Posted October 02, 2017 - 07:37 PM
IMG_1271.JPG This is what the original generator and hydraulic pump set up looks like.  The inner sheave would be used for the cutter bar or rotary mower.  The pump is a Hydreco.  Later models used a Vickers pump.  Tractor is a 1949 with 40L1 loader attachment.
Cliff
#24 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted October 02, 2017 - 08:34 PM
Thanks for the picture Cliff! It looks like a notch is cut in the front pulley for a starter rope. Where did they mount the hydraulic tank? I'm going to the Zagray Farm show near my home this weekend, I hope there will be some Shaw's there to look at. Thanks again, Ted.
#25 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted October 02, 2017 - 08:44 PM
I think i just answered my own question, looks like the reservoir is right under the pump section.Didn't notice that at first.
#26 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted October 02, 2017 - 09:51 PM
Cliff will likely be at Zagray. We had the national shaw meet there in May. Didn't have a real big turnout.  Were you there then?
#27 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted October 03, 2017 - 05:11 AM
Good morning Doug, I didn't get to go to the spring show, wish I had.I live about 10 minutes away from there, but I usually find out about their show after its gone by.Looking forward to it....Ted.
#28 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted October 03, 2017 - 06:41 AM
Maybe you could sweet talk Cliff into bringing an R12 out.
#29 Ted Brown Sr. ONLINE
Ted Brown Sr.
  • 6 Thanks
  • 40 posts
Posted October 03, 2017 - 08:47 AM
I hope he does!Are you coming out this time,I know it's a long way from Ohio.
#30 DougT ONLINE
DougT
    Dog Approved
  • 7,147 Thanks
  • 5,100 posts
Posted October 03, 2017 - 11:06 AM
No, I won't be there. I just came out for the Shaw meet and VGTCOA  regional that we had there in the spring. Cliff has a shovel that stays there permanent.
