Shaw brake pedals
34 replies to this topic
#1 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted August 29, 2017 - 07:32 PM
I haven't seen a Shaw tractor since I was a kid, and I can't remember if they had separate brake pedals for right and left.I've been trying to figure that out from pictures, but can't see the pedals in any of the pics I've seen.I think I see only one pedal on the right, did they only have one pedal for both sides? I'm mainly interested in the R12T model. Thanks!
#2 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted August 29, 2017 - 07:55 PM
They had a brake pedal for each side and the clutch pedal in the middle.
#3 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted August 29, 2017 - 08:22 PM
Thanks for that, Doug. So the left pedal is on the left side next to the clutch?
#4 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted August 29, 2017 - 11:36 PM
i'll try to remember to get you some pics.
#5 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted August 30, 2017 - 05:16 AM
Thanks, that would be great...Ted.
#6 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 02, 2017 - 08:33 PM
Ted, Here are pics of the pedals. The center one is the clutch. The brake bands are under the covers on the rear end housing.
#7 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted September 03, 2017 - 03:44 PM
Thanks for taking the time to do the pics Doug, much appreciated! I wanted to see the pedal setup because, try not to laugh, I'm building a tractor from scratch that will look like an R12T Shaw. I may end up putting both brake pedals together on the right though, it looks a little tricky to run the way Shaw did it. Thanks again and have a good Labor Day!
#8 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 03, 2017 - 05:14 PM
Good Luck and post some pictures of the build. I'd like to see it. If you need any other pics let me know and I'll try to help.
#9 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted September 03, 2017 - 06:10 PM
I will try and post pictures as I go, it will take a while, I spend my lunch time on it at work, and I don't get much free time.So far I've built the frame (heavy 3" channel), have the clutch and trans set up and ready to mount in the frame. I 'm using a complete rear end assy from an older Economy, so the tractor won't have quite as much ground clearance, since the final drives aren't as huge as on the Shaw. The motor is a little newer Wisconsin TJD 2-cyl., with a starter and points ignition, runs really nice. The trans. and clutch are kind of overkill for a small tractor but will do the job. Transmission is a small Clark 5-speed  with a PTO from an old Ford F500, I got it for free and I have a low/no budget to work with.Thank you for the help!...Ted.
  • DougT said thank you
#10 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted September 23, 2017 - 07:58 PM
In the pedal pictures that Doug was kind enough to post, I just noticed what looks to be a hook setup to hold the clutch pedal down.Is that  backwards from a normal clutch, in other words is the clutch "in" or released when it's hooked? I've never seen anything like that.Thanks again, Ted.
#11 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted September 24, 2017 - 01:11 AM
The hook holds the clutch released.
#12 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted September 24, 2017 - 06:43 PM
Thanks Doug! I've taken some pictures with my phone but I can't figure out how to transfer them and compress them, this computer stuff is way, way beyond me.Is there an email address for this site I could send them to?That's likely the only way I could post pictures of this project. Take care, Ted.
#13 KennyP ONLINE
  • 38,243 Thanks
  • 45,873 posts
Posted September 25, 2017 - 07:42 AM
Have you seen the video for posting pics?
#14 Ted Brown Sr. OFFLINE
Ted Brown Sr.
  • 5 Thanks
  • 35 posts
Posted September 26, 2017 - 08:41 PM
Thanks Ken for trying to help...I watched the video, but still having no luck.My computer skills pretty much suck! Thanks again, Ted.
#15 KennyP ONLINE
  • 38,243 Thanks
  • 45,873 posts
Posted September 27, 2017 - 07:21 AM
Are you using a phone to view the forum? If so, I think that works differently.
