allis chalmers shuttle trans
9 replies to this topic
#1 Tommyr OFFLINE
Tommyr
  • 3 Thanks
  • 5 posts
Posted August 29, 2017 - 01:51 PM
just got my 1st gt(allis chalmers 914 shuttle) and  the rearend is locked up what are some common problems with this trans (i got a good mower deck a set of wheel weigts a good series 2 kohler kt19 a ac919 a like new snowblower and a tiller for $500)
  • hamman said thank you
#2 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted August 29, 2017 - 03:02 PM
:wave: Welcome to the forum! Don't know much about these, But I have a 6-speed out of a 716 down here.
#3 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,315 Thanks
  • 4,949 posts
Posted August 29, 2017 - 05:20 PM
Tommy!!!
You are a bad boy!!!!  :(
A member for nearly a year and a half and just now speaking up.
:poke:
'Course we'd forgive you if you post a picture of your tractor.
:wave:  :smilewink:
  • jimmy G said thank you
#4 boyscout862 OFFLINE
  • 12,839 Thanks
  • 9,162 posts
Posted August 29, 2017 - 08:08 PM
Welcome to GTT. First, you should download the manuals for your tractor from the Manuals Section. Somewhere there will be a troubleshooting guide to help you figure out the problem. Good Luck, Rick
#5 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted August 30, 2017 - 08:28 AM
Is this a standard trans model. If it is maybe a problem with the shifter and the trans is in two gears at the same time?? One thing to check before going to deep. ???
#6 KennyP ONLINE
  • 38,274 Thanks
  • 45,881 posts
Posted August 30, 2017 - 09:17 AM
Maybe this 900 Series SM can help you.
#7 Tommyr OFFLINE
Tommyr
  • 3 Thanks
  • 5 posts
Posted August 30, 2017 - 01:13 PM
yes and it is  stuck in i think in 1st
#8 massey driver OFFLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted August 30, 2017 - 02:25 PM
not sure if this video will help you. but take a look and see.
Edited by massey driver, August 30, 2017 - 02:29 PM.
#9 Tommyr OFFLINE
Tommyr
  • 3 Thanks
  • 5 posts
Posted August 30, 2017 - 09:46 PM
yeah ive watched the video  i understand the concept but it will not budge i thik ill have to pull it off and crack it open
  • massey driver said thank you
#10 Tommyr OFFLINE
Tommyr
  • 3 Thanks
  • 5 posts
Posted August 31, 2017 - 08:41 PM
took two hours but i  finally got it unstuck had to  strip everything off the rightside of the rearend just so i could get in there
  • MolonLabe said thank you
