Sears suburban 12
5 replies to this topic
#1 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 764 posts
Posted August 28, 2017 - 10:06 PM
Anybody know if I can change a rear axle seal on a suburban 12 without tearing the thing apart.
#2 1oldbuzz OFFLINE
1oldbuzz
  • 564 Thanks
  • 448 posts
Posted August 28, 2017 - 11:47 PM
I would think its doable
I did it on my bolens
hard part is getting the old seal out
I carefully drilled a small hole
in the edge of the seal
screwed a small sheet metal
screw in and clamped a vise grip
to the screw and tapped the vise grip
with a hammer came right out
  • Gtractor, EricFromPa, boyscout862 and 2 others have said thanks
#3 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 764 posts
Posted August 29, 2017 - 08:11 AM
Thanks 1oldbuzz I will give it a try
#4 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted August 29, 2017 - 08:15 AM
I would think so. Have you looked in the parts manual to see how it's bolted together? That could help seeing what needs to come loose!
#5 Xrperry ONLINE
Xrperry
  • 1,022 Thanks
  • 764 posts
Posted August 29, 2017 - 06:37 PM
Haven't looked yet. Figure someone here has done it
#6 EricFromPa ONLINE
EricFromPa
  • 3,649 Thanks
  • 3,109 posts
Posted August 29, 2017 - 07:06 PM
I drilled a small hole through the ones on my SS15 and used a pretty beefy 3" long wood screw to get them out. Drill a small hole near the outside edge not near the axle. Did have to use the little chisel on the left one. Just dented it enough to loosen it up.
If it gives you problems use a small punch and a hammer and whack dents in it the whole way. That will shrink the metal enough so you can pick it rite out with needle nose pliers.
Edited by EricFromPa, August 29, 2017 - 07:06 PM.
  • 6mikey7 said thank you
