ID This Tool
12 replies to this topic
#1 chieffan ONLINE
  • 9,611 Thanks
  • 6,431 posts
Posted August 28, 2017 - 06:47 PM
Bought a flat of files at an auction yesterday.  Usually files are well used or beyond at auction.  This flat had 4 new looking files laying on the bottom.  Also was this tool.  About 1/2" square and about8" long.  Patented Dec.4 1928.
I saw one in a hardware store a couple years ago and didn't buy it.  Now cannot locate one anywhere - till this one showed up.
  • MFDAC, boyscout862 and Mark 149 J. have said thanks
#2 EricFromPa ONLINE
EricFromPa
  • 3,539 Thanks
  • 3,074 posts
Posted August 28, 2017 - 07:07 PM
Thread file. For cleaning up old crusty or damaged threads on bolts and studs.
https://www.amazon.c...e/dp/B001T4KRHC
The are pretty handy to have for working on old rusty stuff. You should see the big pile of files I bought at an auction a couple weeks ago. lol. The box had to weigh 20lbs. Out of that 20lbs of files I saved a little over 1/2 of the box. Most of the large files were rusted to bad BUT I have something in mind that they can be used for.
Edited by EricFromPa, August 28, 2017 - 07:34 PM.
  • MFDAC, boyscout862, TomLGT195 and 1 other said thanks
#3 GWest OFFLINE
GWest
  • 540 Thanks
  • 495 posts
Posted August 28, 2017 - 07:10 PM
That is a thread file for cleaning up external threads. Think I see a number 11 and number 12 at the end of the files near the center. That is the threads per inch. Great tool for restoring mashed threads. There are 2 different versions for Imperial threads giving 16 different tpi plus metric versions I don't have.
File is used perpendicular to the threaded shaft. Register 1/2 the file on good threads and use the other 1/2 on the damaged threads. Work your way around the shaft.
Garry
Edited by GWest, August 28, 2017 - 07:13 PM.
  • boyscout862 and HANKG have said thanks
#4 chieffan ONLINE
  • 9,611 Thanks
  • 6,431 posts
Posted August 28, 2017 - 07:19 PM
Yep, this one is for SAE 11,12,13,14,16,18,20,24.  Would like to find one is US Standard and a Metric one.  Will keep looking.   Those on Amazon are pricy and takes 4 tools to get the 8 cuts.
  • MFDAC said thank you
#5 CRFarnsworth ONLINE
CRFarnsworth
  • 4,588 Thanks
  • 2,111 posts
Posted August 28, 2017 - 07:21 PM
Yep.  Thread file.  I have a set of those, SAE and metric.
#6 boyscout862 OFFLINE
  • 12,553 Thanks
  • 9,046 posts
Posted August 28, 2017 - 07:44 PM
An old trick to clean and sharpen old files is to put them in a bath of old battery acid. It actually works. The time in the bath depends on how good the acid is. I then dunked in baking soda and water and then into old kerosene. Good Luck, Rick
  • MFDAC, CRFarnsworth, tiretrx and 2 others have said thanks
#7 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted August 28, 2017 - 08:21 PM
Knife makers like to buy bad files.
  • MFDAC and boyscout862 have said thanks
#8 MFDAC OFFLINE
MFDAC
  • 3,155 Thanks
  • 1,569 posts
Posted August 28, 2017 - 08:46 PM
Check with your local welding supplier. We get ours at work from A&B Welding Supply.
DAC
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,223 Thanks
  • 5,683 posts
Posted August 28, 2017 - 10:54 PM
On the farm we dealt with a tons of 20 TPI bolts so we have one with only that size..  I also have the SAE multi version..  If the thing is that toasted it gets replaced in my book..
#10 karel OFFLINE
karel
  • 1,991 Thanks
  • 1,334 posts
Posted August 29, 2017 - 03:08 AM
And I thought it was gong to be something hard to identify! Wait, What? How long this boy been on the planet!
#11 SimplyRad OFFLINE
SimplyRad
  • 1,020 Thanks
  • 788 posts
Posted August 29, 2017 - 08:26 AM
I also have a set of those, SAE and metric. Haven't used mine in years though.
#12 Kster526 ONLINE
Kster526
  • 826 Thanks
  • 548 posts
Posted August 29, 2017 - 08:39 AM
yup a great tool to have when your in a pinch to save the only bolt you have that fits just right.
#13 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,082 Thanks
  • 2,669 posts
Posted August 29, 2017 - 09:05 AM
This set shows on sale at Napa for $68.99 part # SER972 - made by Kastar
Couldn't past a link so here are pictures of the set and contenets - gives you taps, dies and files - just a suggestion
Edited by 29 Chev, August 29, 2017 - 09:14 AM.
