New muffler set up for my Yanmar diesel powered Wheelhorse.
2 replies to this topic
#1 mtoney OFFLINE
mtoney
  • 824 Thanks
  • 685 posts
Posted August 26, 2017 - 11:46 AM
I have felt that the Honda push mower muffler set up on my little 6.5hp Yanmar diesel was a bit restrictive.   Most folks know that  a diesel needs to "breath" to work at its best, both on intake and exhaust side of things.  So, at the Portland, IN swap meet, I found this lagged muffler at a vintage Briggs & Stratton parts booth.  Picked it up for $25.  I shortened up the input pipe and welded up a flanged input set up(Yes I know my bead laying still isn't best, but it holds and seals!).  I also made a support mount at the front of the muffler barrel to support the weight.  The main barrel is lagged with an outer wrapper, so this helps with heat and the paint/decals above it.  The output faces forward, out and down.  So I do not get as much fumes as I was with the the original set up I made up.  Also a bit quieter as with the original set up, I could tell by the sound of the exhaust, the engine was working against some backpressure due to the smal muffler.  I also have a clear lense Tomar Microstrobe to replace the low intensity strobe on the fender now.  Still have to mount it up.  Mike the Aspie
  • akretowicz, KennyP, CRFarnsworth and 4 others have said thanks
#2 KennyP ONLINE
  • 37,385 Thanks
  • 45,444 posts
Posted August 26, 2017 - 01:44 PM
Looks good! Should let her run better!
#3 akretowicz OFFLINE
akretowicz
  • 233 Thanks
  • 313 posts
Posted August 26, 2017 - 02:02 PM
A very neat and compact set up there.  Nice work.
